car quit need help
Old Feb 8, 2006 | 08:28 PM
StreetRacingTA's Avatar
Question car quit need help
a friend of mine has a 93 formula a4 and he was idleing at the store today and his car died. I am trying to help him figure out what is wrong with it. The fuel pump is priming up, and the car will turn over but will not start. I told him to check the opti but he just got the car about 2 weeks ago and doesnt know anything about lt1s. Any suggestions would be appreciated.
Old Feb 8, 2006 | 09:17 PM
93transam1234's Avatar
Re: car quit need help
first thing i would do is put some gas in it, its not uncommon for the gas gauge to be off or broke.
if their is gas in it check for fuel presure at the shard valve right behinf the intake.
Also check for spark from the coil, take the coil wire off the coil and and have ur friend hold the coil while you crank it over a few times, or i guess u could just put a groundd wire very close to the tip of the coil and see if you can see it arching.
thats where i would start then post up
MadMav
Feb 6, 2015 11:02 PM
fpete1992
Dec 11, 2014 03:51 PM
GhostZ28
Dec 7, 2014 11:53 PM
nophix
Nov 30, 2014 10:26 PM
USAirman93
Nov 24, 2014 03:37 PM
