Car Problems
Old Jan 27, 2006 | 01:10 PM
RICEFEDZ28's Avatar
Car Problems
I was driveng along and after about 6-7 miles the car studdered a little then stalled. I tried to start the car and it just cranks over but does not fire. I let it sit for 30 mins and it was fine and drove perfect. Then after driving about 6-7 more miles same thing. After the car cools down it starts right up.I pulled the code it was a P1371 And i cann't seem to find any info. Anyone have any ideas?
Old Jan 27, 2006 | 04:25 PM
RICEFEDZ28's Avatar
Re: Car Problems
Anyone?
Old Jan 27, 2006 | 06:06 PM
QICSAN's Avatar
Re: Car Problems
Time to replace the Ignition Control Module its going bad. It's getting too hot- cools off and works again. Or worst the opti is going out.
LJ
Old Jan 27, 2006 | 09:37 PM
RICEFEDZ28's Avatar
Re: Car Problems
Is there any way to test the ignition control module?
Old Jan 27, 2006 | 11:31 PM
Re: Car Problems
P1371 is for loss of low resolution pulse from the Opti. If the engine actually shut down, its definitely the Opti, or the wiring harness for the Opti. PCM shuts down the fuel system when the low res pulse is lost. The fact that it restarts after cooling down would seem to indicate its the optical sensor module in the Opti overheating.
liamcg97
Nov 25, 2019 05:55 PM
Noenav
Mar 1, 2019 07:38 AM
97SSdude
Dec 31, 2014 07:43 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
USAirman93
Nov 24, 2014 03:37 PM
