car popping
Old Oct 24, 2003 | 12:58 AM
nitro-Z's Avatar
car popping
i have a friend with a stock 94 z,and when he hammers it at anytime,when the rpm's hit 5800,the needle bounces,then car starts popping,then switches into a different gear,what could this be???
Old Nov 9, 2003 | 10:14 PM
94ConvertibleZ's Avatar
If it's happening at wide open throttle right around redline it's probably the EGR valve. Mine was doing the same thing because the bellows tore inside the egr valve creating a huge vacuum leak. The car ran perfectly normal until you tried to punch it the whole way, then it would run lean and pop-pop-pop- was heard under the hood till it shifted. Check it out...egr is heap and easy to replace. -Ryan
Old Nov 9, 2003 | 11:03 PM
jchevy's Avatar
Sounds like the rev limiter to me.
Old Nov 9, 2003 | 11:42 PM
97LT1F-Body's Avatar
I second that too.
Old Nov 9, 2003 | 11:50 PM
blueirocz-28's Avatar
yea, just sounds like his tachometer is waay off.. as all stock tachs are by no means accurate. unless you are referring to a aftermarket tach, then it may be more accurate. and if you're going to get into the EGR valve, make a block off for it and have it disabled in the program...
Old Nov 10, 2003 | 08:34 AM
scoobysnax83's Avatar
the main problem is not that they are inaccurate its that they are too slow to keep up with the engine. Same difference I guess. Another option if you do not think that it is your Rev Limiter would be your fuel filter or a failing pump... Good Luck...
bfmv13trivium
Jan 14, 2015 09:57 AM
Scottylt1
Jan 8, 2015 02:48 PM
hotrod 5210
Dec 22, 2014 07:28 AM
Scottylt1
Dec 4, 2014 12:31 PM
USAirman93
Nov 24, 2014 03:37 PM
