Car noobie needs some tips
Old Jan 9, 2004 | 09:29 AM
phrozen's Avatar
OK, What should I be looking for when I'm buying heads and a cam? I know that unless properly matched the performance wont be as good so how do I match up heads and a cam?
My goal with my car is some where in the neiborhood of 450-500hp at the crank n/a and maintain streetablity and smog-legal in california.
Old Jan 9, 2004 | 09:33 AM
AxeGrinder30thZ's Avatar
I'm building a 355 next year with stock ported/polished heads and a Comp 230/236 cam with 1.6 rr's. There's alot more, but even with that, I was told to expect around 400 at the wheels. That might give you a better idea of what you need.
Old Jan 9, 2004 | 06:25 PM
phrozen's Avatar
that doesn't really answer my question. I want to know what kind of duration/lift I want for what kind of head.
I would also like to know what kind of cams fit in an LT1.
Old Jan 9, 2004 | 06:32 PM
ChickenScreamer94's Avatar
this topic has been talked about numerous times, there are probably hundreds of threads about cams and heads. A search is your best option here.
I do know that a high flow head makes less power at lower rpms, so if this thing is a daily driver that may be a factor for ya.
Old Jan 9, 2004 | 07:25 PM
I know I can't answer you question exactly. I was only trying to give you a slight idea of what you would have to do to attain those goals.
Old Jan 9, 2004 | 09:46 PM
97WS6SCharged's Avatar
Don't want much do ya?
Your best bet would probably be a set of TEA heads or get Lloyd to do a set for you. Then install a hot cam or a CC305 and have it tuned really, really well.
As far as what kind of cams fit into a LT1. Pretty much any hydraulic or solid roller cam for a small block chevy, you just have to have the right dowl pin length. I believe a flat tappet will also fit, but there wouldn't be much point.
Old Jan 10, 2004 | 01:41 PM
phrozen's Avatar
Is what I'm asking really that hard to keep smog legal? damn...
OK, who is TEA and who is Loyd? And who makes a cc305?
Old Jan 10, 2004 | 04:19 PM
Lloyd is a member on this board, do a search and you will see alot of happy customers. TEA is short for Total Engine Airflow, I think you can find a link in the sponsor's page. The CC305 is made by Comp Cams.
Old Jan 10, 2004 | 06:13 PM
phrozen's Avatar
ah, many thanks. I hear a lot of good things about that cam so it is nice to know who makes it.
ModdedNerd
Jan 1, 2015 10:56 AM
Hurin
Dec 13, 2014 07:38 PM
USAirman93
Nov 24, 2014 03:37 PM
97QuasarBlue3.8
Jul 22, 2002 09:09 AM
mosskeet
Jul 18, 2002 08:11 PM
