Car launches forward
Old Mar 18, 2004 | 11:53 PM
94-3.4's Avatar
Question Car launches forward
My car has been weird ever since the swap over a year ago. The engine has a reletivly new optispark and i just replaced the plug wires. It idles very good and runs even better. The problem i am having is when sitting at a stoplight it will sometimes just totally bog out then the rpms will almost imediatly come back up and the car will launch forward. It kinda scares the crap out of me when it does it. Also, on decel i can kinda feel it do a more subtle chug. This is an A4 car and thougts of the tranny causing this are starting in my head. Could this be or should i just slap a new opti on it first?
Old Mar 19, 2004 | 12:21 AM
QCKZ28's Avatar
what stall do you have?
what kind of tuning?
Old Mar 19, 2004 | 02:23 AM
1982z28with18s's Avatar
Could be a vacuum leak. Hows your vacuum?
Old Mar 19, 2004 | 07:28 AM
94-3.4's Avatar
Stock stall, custom tuning done locally. Just started doing this about a week ago when i got it out of storage.
I will check the vacuum today. That is a possibility!
Old Mar 19, 2004 | 09:35 AM
Dan Oldham's Avatar
Could be a motor mount. If you've got a broken motor mount, this can cause the car to just launch forward.
Old Mar 19, 2004 | 11:38 PM
Fatdog's Avatar
Cool
I had the same problem,sitting at a fast food drive through,and all of a sudden,the car has a mind of it's own,reving up ,so I throw it in neutral,then it comes back down.Didn't happen for a while,then it did it again,so I say,screw this,took it to the dealer,and guess what?,the wires on the pass side of the manifold were toast,leading up to th iac,and map sensor,so $150.00 later,problem was solved.Been a year now and everything is good.Hope this helps.
mark0006
Dec 25, 2014 09:50 PM
bernie1951
Dec 10, 2014 10:03 AM
NewsBot
Dec 3, 2014 12:30 PM
USAirman93
Nov 24, 2014 03:37 PM
IgorT.455/406
Jun 4, 2003 03:32 AM
