94 Cloth to 98 Leather
Old Mar 9, 2004 | 01:03 PM
RallyRed701/2's Avatar
i found a good deal on a set of leather seats out of a 98 t/a. the only possible problem is that i have a 94 Z. the seats im getting are both adjustable ones, and right now i only have a power driver-side seat. im just curious if the connector on my z is going to fit the new seats correctly so ill have power. has anyone else done a swap like this? what else do i need if anything to get this swap done easy...? thanks for the help.
and are leather seats out of a ta better than leather seats out of a camaro?
Old Mar 9, 2004 | 01:57 PM
TraceZ's Avatar
Re: 94 Cloth to 98 Leather
The TA seats are nicer than Camaro seats. They provide better support, and look better. They will bolt right in. As for the connector... I dunno. I'd imagine it is the same but you never know.
Old Mar 9, 2004 | 03:09 PM
1984camaroz28's Avatar
it will bolt rite in. and the connectors are the same
Old Mar 9, 2004 | 03:14 PM
LT1TONY's Avatar
I took my '94 Camaro seats out and replaced them with '98 Camaro seats and it plugged in just fine.
Old Mar 10, 2004 | 12:29 AM
thanks guys... i hope you're right...
Old Mar 10, 2004 | 02:47 AM
scoobysnax83's Avatar
post some pics up when you get it done
Old Mar 10, 2004 | 09:43 AM
will do
Old Mar 10, 2004 | 09:47 AM
Anderson's Avatar
lol I saw you posting on LS1.com for them. I was looking for the same thing, but found some on ebay.
Old Mar 10, 2004 | 02:13 PM
ya i got tired of riding around in normal torn up cloth seats that are covered with seat covers that dont match the back...
i think this will make my car look much much better, and make driving a whole lot more comfortable... atleast until the florida summer heat hits...
Old Mar 10, 2004 | 07:34 PM
Anderson's Avatar
Just Carry a cloth in the back of hte seats for when ever you wear shorts, and you'll be just fine. What color seats did you end up getting?
Old Mar 11, 2004 | 12:57 AM
jssws-6's Avatar
I just did the conversion. 97 TA to 2001 TA seats. the plugs were not the same. It was a very easy switch though. My old seats only had a 2 prong power source the new seats had a 6 prong. This is what I did, Went and bought 2 sets of trailer wiring ( 6 prong)harnesses at napa $6.95 each, 1 10ft 4 wire loom $7 at Menards. Now I put 1 end of each harness on the seats and soldered them in. The other 2, I connected to each other by splitting the 4 wire loom in 1/2 and only using 6 wires. Then take every thing to the car and only connect the orange and the black wires ( on the seats) to the wires in the car already, ran an air tube for lumbar.So what I,m saying is for the drivers seat you only need 2 wires but the other 4 run from the drivers to the pass. seat for power. hope this helps if its like mine
Old Mar 11, 2004 | 09:48 AM
man i really wish you had some pics to help me out. that sounds like a lot of work that i dont know how to do, plus i dont have a sodering gun or a Menards (i have no idea what or where the hell that is )... do you have any instructions that are a little more detailed??? pics??? at this point im praying that there isnt a difference between the 94 and 98 harnesses...
Old Mar 11, 2004 | 03:19 PM
jssws-6's Avatar
No pics Sorry!!!! Menards is same as home depo But you can get the harness at a car parts store also. If the wire plugs are not the same I can give you a step by step of what I did. I'll give you my phone # and we can talk on the phone to give a little better description. If there not the same either e-mail me or post it up here ..
.... it was very easy and only took about 1- 2 hours total soldering gun is very cheap $10
Old Mar 14, 2004 | 11:32 AM
alright thanks...ill get ahold of you once i get the seats and see what im working with.
Old Mar 19, 2004 | 11:33 PM
Anderson's Avatar
Just got my seats in and came accros the the problem with the mis matching plugs. I might do the entire routing later, but if I just want to make the drivers side work, all I have to do is connect the 2 wires right??
