Car just quit
Old May 12, 2008 | 10:13 PM
z275plus's Avatar
Angry Car just quit
This thing is driving me crazy. I was just driving down the street today and the car just shut off for no reason. I manage to get it started again then approx 1/4 mile later it cut off again. I could not get it re-started and had to tow it home.
I sprayed some starter fluid in the t-body and it started then died again. Is this the fuel pump or something else ? Also I need the part # for the GM fuel pump.
My vehicle is a 95 Z with a hotcam and pacesetter headers, 2500 stall and 3:42's in the rear.
Old May 12, 2008 | 10:22 PM
Jazsun's Avatar
People are going to tell you to check fuel pressure, search up on that. Is the start fluid really helping or is it coincidence? You could have a fried keep spraying a bit into the tb and see if the motor stays goen for a bit. Where a glove/jacket in case it backfires. Sounds like an opti initially.
Old May 12, 2008 | 10:24 PM
firstlast's Avatar
is it tuned?
Old May 12, 2008 | 10:45 PM
Is the SES light on? Scan it for codes?
Old May 13, 2008 | 12:04 AM
94z28lt1black's Avatar
id check out your coil... mine had a similar issue and it turned out to be the coil. check out the thread titled "i need help and dont know where to start"
Old May 13, 2008 | 02:54 AM
red1984's Avatar
ICM might need to be replaced.
Old May 13, 2008 | 07:25 AM
DAVE00's Avatar
If you take the ICM and Coil to your local AZ or Advance Auto they can test it to see if it's bad. Def sounds like an ICM issue as the Opti would be more sporaddic typically and usually would not just quit without some symptoms.
Old May 13, 2008 | 07:40 AM
93transam1234's Avatar
Fuel, air and spark...witch one are you missing?
Check fuel presure with a gauge that you can buy at any parts store.
Check spark at the coil and the plug wires.
Air is little more detailed, check out the above first then post back.
Old May 13, 2008 | 01:14 PM
mean96z28's Avatar
My car was doing the exact same thing last week. I replaced the opti and a MSD one and it runs like new.
More than likely your cap has corrosion built up in it.
Try replacing your distributor or, if you are short on money, take a look at your cap.
It doesn't matter if it's new or not, I found that it can actually take less than 3,000 miles to make an optio-spark distributor go back. That's what happened to me...
Old May 13, 2008 | 02:34 PM
z275plus's Avatar
No it has not been tuned yet, and the check engine light is on. How can I scan it to see what code show up.
All of the scanner that I have found at the local auto parts store are for obd II.
Old May 13, 2008 | 02:40 PM
reamo04's Avatar
http://www.mainstreamtopics.com/foru...p?showtopic=78
check that site, it will give you a good way to test it
MadMav
Feb 6, 2015 11:02 PM
fpete1992
Dec 11, 2014 03:51 PM
nophix
Nov 30, 2014 10:26 PM
USAirman93
Nov 24, 2014 03:37 PM
DrMilhouse
Oct 2, 2002 05:03 PM
