Car Hesitates To Start Sometimes
Old Oct 19, 2003 | 01:14 PM
CamaroGuy22's Avatar
Question Car Hesitates To Start Sometimes
My car hesitates to start sometimes, on some occaisions it will not turn over automatcially it will take a few seconds of turning the key and giving it some gas to start up. About a month ago or so it didnt start up for a five min period. Whats the culprit for this? And how do I fix it?
Thanks!
Old Oct 20, 2003 | 03:28 PM
I would like some ideas?
Old Oct 20, 2003 | 04:35 PM
NVetro's Avatar
I know how you feel. After you make certin that all your plugs,wires,coil, and opti are good. THEN I would test your fuel presure. If your ignition system checks out then I guarentee you that its a faulty check valve in your fuel pump (likley) or a leaky injector (not likley) If you have a faulty check valve in the pump then cut an access panel and get the Racetronix setup, I love mine If your fuel presure is fine, and it holds presure with the key off THEN I would look into your ignition control moduel. But those rarley ever go bad. I would bet its your fuel pump since its a 95, thats what it was with mine :-) I also
I also forgot to mention, if your ignition system checks out, then replace your fuel filter before you attack the fuel system, it sometimes fixes the issue
Old Oct 21, 2003 | 09:06 AM
Thank you for your response, in the last few montsh i have installed new plugs, wires, and a fuel filter.
jayblev95
Jan 20, 2015 01:30 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
Queens94z28
Dec 20, 2014 09:11 PM
USAirman93
Nov 24, 2014 03:37 PM
IRABuss
Sep 7, 2011 09:08 PM
