Car heats up with A/C on only under load?
Old Jul 7, 2004 | 05:20 PM
shrek127's Avatar
Ok it's a 97 Z28 142 or so thousand miles. Now as of a week ago when under load and a/c on car heats up way past 210 I have a 160 thermostat. Now when I come to a stop or just idiling in say parking lot 3 minutes car is back to under 180. I charged the unit cause it was low, I have good hoses on car, I may need to add more dex than I have water but it should't affect this problem. Guys I am calling on some thinking causeI am all out of ideas. BTW not so bad at Night here in houston but during the day the windows down thing sux. As usual appreciate any and all suggestions.
Old Jul 7, 2004 | 07:39 PM
Hyperspeed97z28's Avatar
its acting fine. dont worry about it, mine does it too, i havent had any problems with it to date (knocks on wood)
Old Jul 7, 2004 | 09:34 PM
It heats up when you are driving? Do have the air dam on? Ground effects on the front?
Old Jul 7, 2004 | 10:49 PM
LT1Squirrel's Avatar
are your fans coming on with the A/c?
Old Jul 7, 2004 | 10:53 PM
I would suspect they are or his temps would really climb in a parking lot instead of going down.
Old Jul 7, 2004 | 11:34 PM
shrek127's Avatar
No, I do not have the ground effects, or the air dam. Yes, the fans kick on. It overheats only with the AC on under a load.
Old Jul 8, 2004 | 07:43 AM
izzyz28's Avatar
If you truly do not have the air dam installed, then you have found your problem. The air dam is the only way that the condensor and radiator receive cooling air, as there are no holes in the front of the car for air to pass through. If you need to buy a new air dam I believe there are a couple of vendors who sell them. Maybe one of the other board members can chime in here and let you know where to order one. GM dealerships may even have them. Hope this helps.
Old Jul 8, 2004 | 08:52 AM
You must have the air dam on.
1993-1997 f-body front air deflector (air dam) 10229657
Old Jul 8, 2004 | 09:38 AM
on a summer day with my 160 thermo, I run around 210 with the a/c in MAX, It doesnt go any higher then this though? This temp is BAD ????
Old Jul 8, 2004 | 11:40 AM
NuMbNuTs670's Avatar
You set your fans at a lower turn on temp and bleeded the coolant systems right?
Injuneer
Dec 15, 2014 09:36 AM
CaRParts102
Dec 6, 2014 08:45 AM
ro2207
Dec 4, 2014 06:18 PM
pologreen97z
Dec 2, 2014 10:42 AM
USAirman93
Nov 24, 2014 03:37 PM
