CAR IS Going crazy possible opti
Old Mar 2, 2004 | 08:39 PM
SLeeper94Z's Avatar
Well I can start my car it till around 1000 rpms then it will jump to 1500 rpms just keep doing that ,car has lost all power , I was driving my car in the rain yesterday when it happened, would the opti affect idle and shifting the car , I cleaned The Iac ,throttle body and maf , still doing it has no power at all could i have a vacuum leak ?
Old Mar 2, 2004 | 08:46 PM
Red96Lt1's Avatar
Well you said it crapped out when driving it in the rain, and opti's are very moisture sensitive, so..............................
Old Mar 2, 2004 | 09:02 PM
SLeeper94Z's Avatar
opti
would the opti make the car rev up to 1800 pms to 2000rpms when i n park?, could the hoses on the passenger side of my throttle body cause the car to rev high? one has a split in it would this act like a vacuum leak?
Old Mar 2, 2004 | 10:39 PM
SLeeper94Z's Avatar
anyone?, could my cpu be the culprit?
Old Mar 2, 2004 | 10:47 PM
95BlackTA's Avatar
http://shbox.com/1/evap_sol.jpg
Is it one of those vacuum lines? I had the bottom one(EVAP) unplugged for months, didnt make the car drive any different.
And yes a bad opti would cause the car to have a bad idle, like trying to take off then calming back down.
Old Mar 2, 2004 | 11:22 PM
Compstall's Avatar
I personally haven't had that type of characteristic when my opti has gone out on me.
My car actually runs fine when it's cold, but when it gets good and heat-soaked is when my opti rears its ugly head. That's when it starts to buck and surge, and runs on 5-6 cylinders. If I REALLY baby it, and don't put it under any kind of load, I can limp it home. Can't wait 'till Thursday when I can finally get to it and change it. I've really been tied down to the local area, and going to work only and back home, and that's driving me nuts!
Old Mar 2, 2004 | 11:34 PM
SLeeper94Z's Avatar
I mean I can just go outside start the car it acts like someone is revving the engine for me does anyone know what all causes this ?
Old Mar 2, 2004 | 11:51 PM
SLeeper94Z's Avatar
well i did get the car scanned the other day I had a code for Iac,Maf,and right O2 i think and trans output sensor, then we turned the car back off scanned again and code 51 ecm prom error, and trans ouput sensor, do u think MY cpu went bad and threw these codes, because it was running fine then just started surging and the rpms would go crazy do you think the mass would go bad and the Iac at once and cause these problems or do u think my ecm is just messed up, I mean I don't want to replace all these parts If the ecm is giving me false readings, what do you all think I should do
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Injuneer
Dec 15, 2014 09:36 AM
pologreen97z
Dec 2, 2014 10:42 AM
USAirman93
Nov 24, 2014 03:37 PM
GigaMp3z
Feb 20, 2003 02:57 PM
