Car dies when decelerating...
Old Aug 18, 2007 | 04:36 PM
Myxtreme1's Avatar
This has happened a couple times since my motor build. I don't know if it has something to do with the stall convertor or if I need to raise the rpm @ idle. When cruising at a reasonable speed or the cruise being set, I'll let off the throttle completely and it's like it instantly goes into neutral and the rpm's go straight down. Almost everytime itre covers itself and guns back up, but sometimes it just flat out dies. Any ideas?
Old Aug 18, 2007 | 08:05 PM
Z28LT1_Just_Nasty's Avatar
Try cleaning out the IAC and give it a shot. I know a lot of guys have stalling problems due to a faulty one.
Old Aug 19, 2007 | 11:06 AM
Myxtreme1's Avatar
Can the parts store test it to see if it is bad? I don't know when I will have time next to do it.
Old Aug 19, 2007 | 05:06 PM
Sparkz28ss's Avatar
it takes 10 min to take out and check......longer then it would take you to go to the store...have some kid tell you to buy a new one anyway...and then drive home
Old Aug 20, 2007 | 04:08 PM
Myxtreme1's Avatar
I'll work on that. I had it out like 2000 miles ago when we built the new motor, but I'll see if it looks bad.
Old Aug 21, 2007 | 01:14 PM
neal38's Avatar
i read that a faulty EGR valve will cause that. hope it helps
bfmv13trivium
Jan 14, 2015 09:57 AM
ModdedNerd
Dec 18, 2014 10:52 PM
nophix
Nov 30, 2014 10:26 PM
Ricardo
Nov 29, 2014 10:58 AM
USAirman93
Nov 24, 2014 03:37 PM
