Car dies out, gauges bounce, lights flicker?
Old Jan 31, 2006 | 02:30 PM
danny525's Avatar
Question Car dies out, gauges bounce, lights flicker?
While im driving, my car will just cut out and die, when it dies, all the warning lights flicker on and off, and the speedos bounce around. I can pull over usuallty and turn off the car and turn it back on. And then it runs and drives fine. Well thats at least how i got it to a mechanic. Just seeing what all yo guys think it is?
Old Jan 31, 2006 | 02:35 PM
danny525's Avatar
Re: Car dies out, gauges bounce, lights flicker?
oh ya, besides when it decides to start to die out, it runs and drives great.
Old Jan 31, 2006 | 03:08 PM
1SlowFormula's Avatar
which car?
But guesses are,
  • Bad gas?
  • Stalled the M6 thinking you were driving the A4?
  • anything...
Old Jan 31, 2006 | 03:10 PM
JakeRobb's Avatar
Super Moderator
Just a hunch, but it sounds like an electrical problem to me. Check your battery ground, your alternator ground, and keep an eye out for other symptoms.
Old Jan 31, 2006 | 03:27 PM
Javier97Z28's Avatar
Moderator
Ignition module is a guess...
Check fuel pressure as well when it's doing it.
Old Jan 31, 2006 | 03:32 PM
transAMdriv3r's Avatar
my friend just had this problem, the altenator was shot.
Old Jan 31, 2006 | 03:37 PM
Joe 1320's Avatar
Bzzzzzt.............
The answer is the ignition switch. When they start to fail, the car can run and drive perfect and then suddenly die. Sometimes the car will restart, sometimes it won't do anything. What leads me to the ignition switch is that all the power to the gauge cluster runs through the ignition switch. If you notice your gauges doing whacky things, the car randomly dies, sometimes restarts, sometimes won't turn over at all, replace the ignition switch. It is located on the topside of the steering column about 2/3 of the way down the column. You will need to remove the lower dash cover and drop the steering column down to access the switch. The cost is roughly $25.
Old Jan 31, 2006 | 05:45 PM
OBE1 95Z28's Avatar
Another vote for the ignition switch.
Old Feb 3, 2006 | 01:40 PM
danny525's Avatar
sorry it took so long to get back to ya, but ya its the A4, does what you guys are saying, it suddenly dies, sometimes it runs great, sometimes when it dies, it starts right up, sometimes it doesnt, all the lights flicker, and the speedos bounce around. sometimes when it dies, and you try to start it, its like it has a dead batterie, then it almost starts but cuts out, then it might start up. Always diffent. thanks for all the input
Old Feb 3, 2006 | 02:24 PM
WS Sick's Avatar
Check your battery cables and your grounds on the front of the block and the padd side just below the head in the middle of the block.
Old Feb 3, 2006 | 09:03 PM
danny525's Avatar
thanks for all the help, just to let you know it was a bad ground! The worst thing is figure it out after i did the beotch of a job to put in that ignition switch!, but the ground was touching from a mystery washer to the power on the part near the battery that has a bunch of grounds and a power under a cover. Dont know why it was there, must of been something with the old owner ( just bought the car) but ya its 100% the problem. Figured it out by waiting for it to die completely and opened the hood and shook wires till lights came on. agian thanks for all your help
Red Hawk 94
Mar 18, 2019 04:03 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
A's 91 Z28
Dec 7, 2014 12:09 PM
nophix
Nov 30, 2014 10:26 PM
USAirman93
Nov 24, 2014 03:37 PM
