LT4 ED timing set... is it a REQUIREMENT?
Old Feb 3, 2006 | 12:34 PM
MeanGreen97Z's Avatar
Im doing a small cam along the lines of an LT4 HOT cam... think the LT4 piece is overdoing it? Can a stock OE replacement set handle the job? I've heard of the stock pieces coming apart on people. I just dont wanna overdo it this time. I always seem to go overboard with what I do to these damned cars. LOL
Old Feb 3, 2006 | 01:04 PM
sabre81's Avatar
Re: LT4 ED timing set... is it a REQUIREMENT?
Stock timing chain will be fine. If you do a search, you find many people running small cams and even larger cams with the stock timing set.
Old Feb 3, 2006 | 02:55 PM
ABA383's Avatar
Stock chain since 1995 running 11s...Freshened the top end last year with a Joe O. cam and replaced the stock chain with a new stock chain...You'll be fine...
--Alan
Old Feb 3, 2006 | 02:59 PM
blkchevyz's Avatar
i just put a new stock chain on mine at the last cam change.
mine see 6500 all the time.
Old Feb 3, 2006 | 04:31 PM
2000GTP's Avatar
Forgive me for imposing on your thread, but I am in the same situation. So if I were to use the XE 224/230 cam., then I should still be okay with a stock replacement set?
Old Feb 3, 2006 | 04:35 PM
Cmr0z28's Avatar
I wouldn't use the stock set, but that's just me.
Old Feb 3, 2006 | 08:27 PM
Loadre's Avatar
That will work fine.
Old Feb 3, 2006 | 09:40 PM
Jameslt1TA's Avatar
The stock timing chain will be fine....i just went with a double roller for added peice of mind and the e-water pump for more power.
LeftoverChinese
Jan 14, 2024 03:03 PM
Jul 4, 2005 05:00 PM
Wilson
Jul 21, 2002 05:08 PM
