Car died on me on the road cranks but no start?
Old Sep 1, 2008 | 08:24 PM
  #16
LaredoZ28's Avatar
Sounds like you have a bad opti. Get the GM one and i always change the cap and rotor to aftermarket.
Old Sep 2, 2008 | 11:33 AM
  #17
sabedra211's Avatar
hmm i baught one of these last night. http://cgi.ebay.com/ebaymotors/ws/eB...262628340&rd=1
Are these one of the "fakes" all Ignition was selling? the Add says "Unit is produced by AC Delco Manufacturer
Complete Ignition Distributor
100% Brand New
This is a Direct Replacement Part"
I already paid 4 it.
Old Sep 2, 2008 | 12:06 PM
  #18
rngilliland's Avatar
That's the one I bought. I've only driven the car 100 miles since I installed it, so I don't know how long it may last, but it works fine now.
I opened my old opti and the problem was the bearing failed and the bottom of the rotor got so hot it melted. Everything else looked very good after 93000 miles.
Old Sep 2, 2008 | 12:39 PM
  #19
sabedra211's Avatar
Oh did the opti you ordered a true ac delco? Did it come in an ac delco box?
my previous opti was from ebay too the seller was ALL ignition it lasted me about 1000 plus miles. When i took it off it sounds all loose and when i spin the spline its all grindy and the number 4 connection is burnt black. but im getting it exchanged.
Old Sep 2, 2008 | 01:07 PM
  #20
It's not AC/Delco. It's an aftermarket part which is what I was expecting.
Old Sep 3, 2008 | 12:32 PM
  #21
1995blackttopta's Avatar
Originally Posted by sabedra211
Does oil messup an opti? I have an oil leak coming from the front of my engine i dont know if its leaking in the opti, if it is could it damage the opti? Can Autozone test out ICMs? Auto zone has an ignition module the brand is Duralast, is duralast a goodbrand? Sorry about all the questions
mine did something like this a few weeks ago after an engine detail, it was running kind of rough, then just died and wouldnt restart... after cranking it for 5 mins or so and then just letting it sit for 20, it started up and was running kind of rough but i decided to drive it home, halfway home the car started running fine... i think the opti just got a little wet
Old Sep 3, 2008 | 01:06 PM
  #22
jhthornley's Avatar
markthomasbrand has it right
Originally Posted by MARKTHOMASBRAND
Hi,
You say you have checked the plug wires,did you also check the wire from the coil to the opti-spark ?
Regards,Mark.
This was my problem when that happened...
Old Sep 3, 2008 | 10:09 PM
  #23
sabedra211's Avatar
Anyone know why the plug connection on the dis. cap could be black?? all of them were bronze except the number 4 one was Black?
Old Sep 4, 2008 | 08:40 AM
  #24
LaredoZ28's Avatar
sounds to me like it was not connected all the way and arked across to the plug wire.
Old Sep 6, 2008 | 10:37 PM
  #25
sabedra211's Avatar
Whoo i just finished with the opti install in my car and my car fired up on the first turn! ... Has camzaro and rngilliland figured out their problem on there camaros??????
ModdedNerd
Dec 18, 2014 10:52 PM
Ricardo
Nov 29, 2014 10:58 AM
tds1213
Nov 27, 2014 12:55 PM
USAirman93
Nov 24, 2014 03:37 PM
1LEThumper
Jul 14, 2003 12:45 PM
