car died in intersection today!! NEED HELP
Old Feb 11, 2006 | 08:31 AM
fastformula309's Avatar
Thumbs down car died in intersection today!! NEED HELP
Latelt my car has been misfireing and sometimes it would have trouble starting. At first i didn't think it was the ingnition i thought it was fuel related because the otispark and rest of the ignition onlt have 5000 miles on them. But yesterday the car died on me on the highway and now it won t even crank over. You can hear the solenoid and the starter start cranking but then it stops?? Its not the battery because i already had a booster pac on it. ANY IDEAS WOULD BE GREAT.
Old Feb 11, 2006 | 08:34 AM
Re: car died in intersection today!! NEED HELP
oh and when it would have trouble starting i would play with the wire from te coil to the distrobutor because that comes loose sometimes, but it didnt work this time?? TYhink it might be a short somewhere or something?? I dont know buts its agravating!!
Old Feb 11, 2006 | 08:48 AM
MENEGRANDE's Avatar
check my post gave up on lt1 same symptoms...
Old Feb 11, 2006 | 09:36 AM
yup thopse are some pretty close symptoms thanks
Old Feb 11, 2006 | 10:10 AM
crAzy95z28's Avatar
change ur coil!
Old Feb 11, 2006 | 11:19 AM
Boosted_Z28's Avatar
If the car won't crank (which is defined as when the ign. switch is turned to the "start" position and the starter is actually turning the engine over) then the coil is not the problem. This condition that you are experiencing has been discussed here many, many times and people have posted the proper troubleshooting sequence to follow that will allow you to determine what has failed and what needs to be repaired/replaced. Just search in this forum for your car's condition and you will find all the information you need. Also, check out Shoeboxes website for great troubleshooting tips: http://shbox.com/page/index.html
Old Feb 11, 2006 | 11:24 AM
Dave89IROC's Avatar
ignition switch?
Old Feb 11, 2006 | 12:17 PM
TRYTOTEST's Avatar
possible ICM
Old Feb 12, 2006 | 08:05 PM
just put a new starter in the car and it cranks over perfectly fine. Now for the missfire.... I put a new fuel filter in... helped a little at low rpm with out stepin on it, but it still missfires when i get on it pretty bad
Old Feb 12, 2006 | 08:11 PM
oh and the coil along with the rest of the opti and ignition only have 5000 miles on them, do you think i got a bad coil and its bad alredy or something else
Noenav
Mar 1, 2019 07:38 AM
bfmv13trivium
Jan 14, 2015 09:57 AM
nophix
Nov 30, 2014 10:26 PM
Ricardo
Nov 29, 2014 10:58 AM
USAirman93
Nov 24, 2014 03:37 PM
