Car is cutting out....why??
Old Nov 9, 2007 | 06:36 PM
speed76demon's Avatar
This started the other day, and I don't know what it is. Whenever I get on it, my car will cut out and stutter. It doesn't start to stutter until about 3k. My car does have 112k miles, so maybe it is plugs, wires, maybe opti? Or is this fuel related? Any help is greatly appreciated
Old Nov 9, 2007 | 06:49 PM
mrmint69's Avatar
Check the fuel pressure using a gauge while driving and see what it does. Tape it to the windshield.
Old Nov 11, 2007 | 07:57 PM
Oxygen454's Avatar
I had the same problem and it ended up being spark plugs. All in all a good tune up would help. Plugs, maybe wires, oil, fuel filter, etc... if its the fuel pump, do the easy cut out idea instead of paying someone to remove your rear end and dropping the tank.
Old Nov 11, 2007 | 08:01 PM
2000GTP's Avatar
When was the last time the plugs and wires were changed?
Old Nov 11, 2007 | 08:03 PM
Oxygen454's Avatar
plugs about 3 weeks ago when I had the problem and has been running like a new car. Before it didnt even want to spin the tires now they wont stop spinning haha.
Wires about 2 years ago.
Old Nov 11, 2007 | 08:06 PM
Oxygen454's Avatar
Also try tapping the MAF sensor on the air intake when the engine is running. If it makes the car almost die or actually dies then its your MAF. Dirty or broken. Just tap it don't beat it obviously.
Old Nov 11, 2007 | 11:57 PM
whitehooptie's Avatar
I had a buddy with a very similar problem. Turned out that his coil wire wasn't on all of the way and was arching through the boot on the opti side.
It would drive perfect with no problems until he stood in it.
Old Nov 12, 2007 | 04:08 PM
bufmatmuslepants's Avatar
just for $hits and giggles, check your cat. mine was clogged and the car would NOT rev past 4000rpm and felt slow and studdered past 3000. costs nothin to check it, might as well.
Old Nov 12, 2007 | 05:06 PM
971t1ss's Avatar
85% of the time the problem is going to be electrical. start with the cheapest part/way to check whether or not the part is bad. swap coil/icms with a willing donor car or friend.
if pluggs have not been done for a while it would be one of the cheapest replacements. pluggs foul commonly with headers.
Old Nov 15, 2007 | 04:01 PM
sn8ke eatr's Avatar
sounds like an opti, possibly a clogged fuel filter. or possible your t.p.s ( throttle position sensor) this happene to my friends car and it acted similar to what your describing.
Old Dec 10, 2007 | 07:20 AM
This turned out to be my fuel pump. The only fuel pressure gauge that I had access to had the wrong fitting for my schrader valve, so I had a guy hit my fuel tank while I tried to start it. Everytime he hit the fuel tank, the car would try to start. Put in the new fuel pump, and everything works great
cmdeshon
Dec 12, 2014 10:51 PM
Dec 4, 2014 11:56 AM
USAirman93
Nov 24, 2014 03:37 PM
squarehead
Nov 21, 2014 08:02 PM
Timberwolf
Jul 20, 2002 08:45 AM
