Car cranks for about 15 seconds before it starts.
Old Jun 17, 2004 | 09:39 PM
gearheads78's Avatar
I have a friend that just put a 97 LT1 out of a wrecked Fbody in an old car. There are no emmisions and no VATS in the computer. It is not losing fuel pressure but everytime you go to start it the motor takes a good 15 sec of cranking before it starts. Once it is started it runs perfect. There is no spark issues at the top end this thing runs great. It just wont start right. Any ideas what it could be or anything can you think of to check?
Old Jun 17, 2004 | 09:47 PM
ninetythreez's Avatar
You mean not losing fuel pressure while idling or not losing when key is turned on but car not running yet? Does it do this after car has sat for a while or only when hot or all the time?
Old Jun 17, 2004 | 10:07 PM
He says that it does it all the time. Hot or cold. He says that is not losing fuel pressure after sitting. Thats the first thing I thought when he was explaining the problem.
Old Jun 17, 2004 | 11:10 PM
Tofus 93Z28's Avatar
swag
fuel filter?....... pump...........how long does it take to reach spec psi...............more input
how old is the gas?
Old Jun 18, 2004 | 12:32 PM
HBHRacing's Avatar
I would see if there is a code for loss of the high res signal from the opti
Queens94z28
Dec 20, 2014 09:11 PM
ro2207
Dec 4, 2014 06:18 PM
1996LT1Z28
Dec 1, 2014 01:01 AM
USAirman93
Nov 24, 2014 03:37 PM
Queens94z28
Nov 20, 2014 06:03 PM
