Car backfires
Old May 24, 2005 | 09:42 PM
KillWhitey's Avatar
Car backfires
I just finished my lt header install 2 days ago. Got my new ovc wires in yesterday and got them on today after work. I started the car just fine and it idled perfectlly. I went to back it out of the garage, pushed the clutch in and then when i gave it just a little bit of gas it backfired. And as i was pulling it up the driveway (to my spot) it backfired the whole way.
I was thinking that maybe i just crossed a plug wire?
Suggestions please
Tim
Old May 24, 2005 | 09:43 PM
Bow94z's Avatar
Re: Car backfires
could be lack of backpressure, i have just a borla catback, and mine backfires all the time
Old May 24, 2005 | 09:48 PM
KillWhitey's Avatar
Re: Car backfires
Did this happen to anybody else when they started their car with open long tubes???
Old May 24, 2005 | 09:56 PM
jchevy's Avatar
Re: Car backfires
Did you unplug your O2's?
It may be that, or you crossed a wire. Car should run fine with open LT's.
I am reading it like it back fires when you press the gas, not let off.
Old May 24, 2005 | 09:58 PM
KillWhitey's Avatar
Re: Car backfires
Yes my o2's are off. I could not get the one out of the pass side manifold So i ordered new ones and they will be in tomorrow. And it does backfire when i push the gas not let off.
Tim
Old May 24, 2005 | 11:29 PM
ZMAN Z28's Avatar
Re: Car backfires
If you have a crossed plug wire, then it wouldn't idle very good at all. But it wouldn't help to re check your wire placement.
I can't say as to your o2's not being connected though. I guess it could cause that, but I don't know, so maybee someone else can help more on this issue.
Z
Old May 24, 2005 | 11:32 PM
jchevy's Avatar
Re: Car backfires
The car will run fine with the O2s disconnected, it will just never jump to closed loop.
Old May 24, 2005 | 11:39 PM
KillWhitey's Avatar
Re: Car backfires
So its a plug wire?
Tim
Old May 24, 2005 | 11:45 PM
KillWhitey's Avatar
Re: Car backfires
What else could possibly cause the backfire? I will go back and check the wiring again after work tomorrow but what else should i look for?? Maybe an unconnected sensor? I will also put the new o2's on tomorrow.
Tim
Old May 25, 2005 | 06:34 PM
KillWhitey's Avatar
Re: Car backfires
I crossed 5 and 7. I was just glad to find the cross on the driver side. Thanks for all the help.
Tim
bfmv13trivium
Jan 14, 2015 09:57 AM
Dyoung_Z28
Nov 25, 2014 05:26 PM
USAirman93
Nov 24, 2014 03:37 PM
F(ast)-body
Feb 26, 2003 09:05 AM
supercharged94Z28
Feb 24, 2003 10:22 PM
