Caprice LT1
Old Aug 25, 2007 | 05:39 PM
PETROC's Avatar
Caprice LT1
So after blowing up my race cars LT1, I picked up an LT1 from a caprice police car. I didn't get a computer, how bad do you think it's gonna run with my current 95 computer having the rion heads?
Old Aug 25, 2007 | 06:24 PM
Dave89IROC's Avatar
will run fine, as long as it really came from a cop car(I.E>, make sure its the 5.7, and not the 4.3 "baby LT1")
Old Aug 25, 2007 | 06:48 PM
dangalla's Avatar
i have heard that as long as you use the injectors from your car you will be just fine
Old Aug 25, 2007 | 07:11 PM
pizzi-man's Avatar
use all your sensors from the original motor and your computer wont know the differance.
Old Aug 25, 2007 | 07:30 PM
96capricemgr's Avatar
You have not gotten any good replies too this point.
The 4.3L was base engine in ALL the 94-95 Caprice sedans be they civilian or police use, and the 5.7L was optional be they civilian or police use. Wagons were 5.7L standard as were Fleetwoods and Roadmasters.
The b-body LT1s got the same 24lbs injectors the LT1 f-body did 94-97.
All the sensors except for the MAF are the same and the b-body has 2 knock sensors instead of one, there was a PN change for all 94-5 use one PN and 96-97 use another, 96 everything got a CPS the earlier stuff lacked.
The water temp sender for the dash is in the passenger side head on the b-body, can just move it too the drivers side for the f-body.
The f-body tuning wont be quite right for the b-body motor but is close enough it will run and drive safely and fine.
Only real possible snag would have been if you had a 93 with the 22lbs injectors and then used the 24lbs from the Caprice but you said your computer is a 95 so I doubt you have a 93 so no issue.
The pcms are actually the same hardware for the same years it is just the software that changed, cheap and easy to modify.
Old Aug 25, 2007 | 09:41 PM
PETROC's Avatar
Great information! THanks for the help. Sat it in today, hopefully running tomarrow!
SinisterRacing1
Mar 7, 2015 03:44 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
redzed
Aug 31, 2002 01:00 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
