lifter problems Help ASAP
Old Aug 25, 2007 | 10:41 PM
Romero155's Avatar
Alright So i installed a set of 1.6 rockers on my car last week with new pushrods, guidplates, springs, etc. Last night i was driving my car and suddenly my car starting taping really loud and ran like crap. I open the valve covers today 2 rockers were totally off the studs and laying next to the spring One of the pushrods was bent in the shape of the letter U. So i reinstalled everything, replaced pushrod, set zero lash. The lifter/pushrod that was bent started squirting oil out of the tip of the pushrod like it was squirtgun. Do you guys think i jacked up the lifter as well?
Old Aug 25, 2007 | 11:29 PM
tagz's Avatar
You have to make sure you REALLY tighten the locks on the rockers. i tighten the allen key as tight as i can get it with a t handle type allen wrench, then give it an additional alittle turn to really lock it down. I set mine at 1/4 turn, so the extra little turn isn't gunna hurt anything. Jus keep it uniform on all the rockers.
As far as the lifters, they should be fine. I'm assuming you had self aligning lifters
Old Aug 25, 2007 | 11:31 PM
tagz's Avatar
never mind, i saw that u said guide plates. Either way, lifters SHOULD be fine, but if you are worried about it pull the intake and take a look.
Old Aug 26, 2007 | 12:28 AM
dangalla's Avatar
i would not be suprised if you had a lifter problem there, do you have access to another one to swap in there to be sure
and by chance did you poly lock just come loose or did the top of the nut bread off, i have heard a story about this
Old Aug 26, 2007 | 12:49 AM
Me>you's Avatar
By bread, you mean break...Just for those here who are a little slow...Which means all of you
Old Aug 26, 2007 | 03:23 AM
Romero155's Avatar
Well i tighted the poly locks down really tight i thought, it happened on the #6 cylinder. The exhaust rocker poly lock actually came off while the intake rocker got loose enough to were it just spun off the pushrod. I guess i didnt tighted the poly locks tight enough, do any of you guys use locktight like the blue one?
HectorM52
Jul 30, 2017 11:46 AM
Heathen1
Jan 2, 2016 04:27 PM
PublicEnemy1
Apr 7, 2015 12:21 PM
jj_burchiel
Classic Engine Tech
Mar 13, 2015 11:20 PM
siguy
Nov 27, 2014 10:07 AM
