Capping Waterpump.
Old Nov 21, 2011 | 12:14 AM
ShowOff67's Avatar
Capping Waterpump.
so my ac condenser is on its way out, gonna by the bypass pulley. i was just wondering how can i cap off the outlet that connects to the ac condenser hose? do the outlets on the 95 lt1 waterpump unscrew? i was told they are threaded so if i can unscrew one napa sells a cap that screws right in is this true?
Old Nov 21, 2011 | 12:35 AM
my1994z28's Avatar
Re: Capping Waterpump.
The AC has nothing to do with the water pump..you can remove your ac compressor without having to touch your water pump.Also you can buy a by-pass pulley made by Dorman for 40.00 and remove the complete ac compressor and bolt the pulley right in its place..I think this is what you were trying to ask..
Old Nov 21, 2011 | 03:01 AM
ShowOff67's Avatar
so what is the hose running from the bottom of the waterpump it looks like the hose runs to the back of the waterpump? or is this the heater hose.
Old Nov 21, 2011 | 05:21 AM
See Shoebox's diagrams:
http://shbox.com/1/95-97_hoses.jpg
http://shbox.com/1/heater_hoses.jpg
As noted, no connection from the water pump to any part of the A/C system. Sounds like you may be looking at the oil cooler bypass hose.
Old Nov 21, 2011 | 12:29 PM
ShowOff67's Avatar
ok so my heater outlet hose created a gaint bubble in it right were it connects to the nipple. no idea how this happened..
Old Nov 21, 2011 | 01:41 PM
bw_hunter's Avatar
As these hoses age they weaken from the inside.....blowing up like a aneurism is pretty common. If your hoses are original, and they probably are, the newest they can be is 14 years old.
BTW, it helps if you make a signature so we can address year-specific items or get a look at what you've modified when giving advice....
Old Nov 21, 2011 | 02:54 PM
ShowOff67's Avatar
im sorry. the Car is a 1995 z28 m6 all stock. just a hooker exhaust, and a k&n intake. just wondering if i could do the same thing shbox did on this heater hose? http://shbox.com/1/heater_hose_repair.html could i do this for the bottom heater hose also?
Old Nov 22, 2011 | 02:26 PM
formula90's Avatar
That is a coolant line, not a heater hose. That line he is referencing costs a pretty penny to purchase new, which is why he shows how to clamp it off with new hose.
If at all possible, I would replace whole lengths of hose at a time.
Old Nov 22, 2011 | 02:33 PM
bw_hunter's Avatar
I don't know what you're talking about...that is the forward end of a heater hose. Both heater hoses have those same fittings at both ends. And,yes, the repair Rob has outlined will work on them as well....
Old Nov 22, 2011 | 02:36 PM
formula90's Avatar
Of course. I stand corrected. Sorry for any confusion.
Formula Steve
Sep 19, 2023 08:31 AM
93 RedBird
Nov 15, 2015 08:24 AM
jayblev95
Sep 26, 2015 09:44 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
heus
Sep 8, 2015 12:01 PM
