Canton Road race pan leak question?
Old Jul 19, 2007 | 03:53 AM
SteveNof1995's Avatar
Although I love the design and engineering of my Canton Road Race pan I hate the fact that it drips oil from the plug. I've had it for a couple of years and I've tried different crush washers and even teflon tape around the threads and it still leaks....Any solutions??
Old Jul 19, 2007 | 04:41 AM
SS Joe's Avatar
Mine leaks too...I have only done one oil change so far (right after break in), and was hoping a new seal around the plug would fix it.
Old Jul 19, 2007 | 10:44 AM
KGRESOCK's Avatar
I had to teflon tape mine....had the same problem.
Old Jul 19, 2007 | 11:35 AM
mike2244's Avatar
i put the washer that came with my felpro gasket set and have not had a leak, it is just a plastic washer.
Old Jul 19, 2007 | 11:04 PM
and the teflon tape solved your problems completely?...i tried doing that once and it still leaked
Old Jul 19, 2007 | 11:06 PM
so did you just get rid of the copper crush washer then??....if that plastic washer works....does it have a part number and/are there any easy ways of identifying and aquiring one?...i'm open to other suggestions too
Old Jul 19, 2007 | 11:21 PM
mdacton's Avatar
you can get a plastic/ rubber oil plug gasket at your parts store.
Most are in bins...just know what size your plug is.......the rubber caoted washer(looks like a A/C washer) works for leaky plugs pretty good
Old Jul 20, 2007 | 06:20 AM
96lt4vette's Avatar
Also look closely at the seat surface for the plug (on the side of the pan) to make sure it's smooth/flat. Mine had a small weld drip on the bung on the pan which caused the washer not to seat fully. I had to file it down and replace the washer.
PCLZ28
Dec 24, 2015 05:19 PM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Queens94z28
Dec 20, 2014 09:11 PM
Elcojoe
Nov 17, 2014 10:27 PM
