Canton Oil pan question
Old Feb 3, 2007 | 09:32 AM
arcticz28the383's Avatar
I know you can take out the stock oil pan with the engine in the car, put could I install Canton with the engine in the car? I wasnt able to install a windage tray because of my 383 setup and I ran out of funds (stupid i know) but know that I got the money Im just trying to figure out the easiest way to do it. Has anyone tried dropping the cradle and supporting the motor from above?
Old Feb 5, 2007 | 09:18 AM
TQdrivenws6's Avatar
I have taken my canton out and put it back in a couple times with the engine in the car yet. I just drop the K-frame and support the engine with my hoist. When you install the canton, put it in without a gasket once and turn it over by hand. More than likely you will need to clearance the scraper. Also watch the gasket, I have to trim the flange where the rod bolts pass.
Old Feb 5, 2007 | 02:44 PM
94/96ZsM6s's Avatar
make sure you only put 6 quarts of oil in the system(5qts in pan, 1qt for the oil filter, if using a full quart filter). oil level will be on the bottom twist of the dip stick. don't put 8 in like i did....especilly with a 383.....
HectorM52
Jul 30, 2017 11:46 AM
Queens94z28
Dec 20, 2014 09:11 PM
Elcojoe
Nov 17, 2014 10:27 PM
