Canton Oil Pan/Exhaust Clearance?
Old Oct 16, 2005 | 09:02 AM
Thor1212's Avatar
Exclamation Canton Oil Pan/Exhaust Clearance?
Has Any one heard about this? I am having my mechanic put in a Canton oil pan into my 1994 LT1 Z, (only because I cant do it myself). He was concerned because the old exhaust had about 10mm clearance, and with the Canton Oil Pan, there seems to me NO Clearance. I am going to change the headers in this Z, but not for a bit longer, maybe a month. Is it a problem to have it butt up against it? Is there a wrap of some kind, that can be applied to keep it from rubbing? Any help is appreciated.
Old Oct 16, 2005 | 09:19 AM
Admiral94's Avatar
Re: Canton Oil Pan/Exhaust Clearance?
Obviously that's not a good situation to have the exhaust right up against the oil pan. You'll be transfering heat into the oil. I guess you can try some of that high temp exhaust wrap, but why don't you just wait to install the oil pan until you do the headers.
Old Oct 16, 2005 | 09:28 AM
Thor1212's Avatar
When i purchased the Canton Pan, I asked a few questons and nothing in the answers lead me to believe that there would be a problem installing it now. The Pan is ready to go in, so i am kind of in the middle of the install. I'll Look for the wrap in an Autoshop and Slip it in there for the time being.
SergheiS
Jul 5, 2015 03:27 AM
TAChad
Jun 14, 2002 03:44 PM
