Canton 242T users with Hooker LT headers...
Old Aug 12, 2007 | 10:05 PM
SS RRR's Avatar
I'm sure I'm not the only one to encounter this... the headers may have to be loosened up in order to get the level sensor plug into the sensor and I'm not even sure it'd clear enough to not melt the plug.
Any tips on this? I was thinking of just putting a resistor in the sensor plug itself. If anyone has done this let me know what size resistor?
Old Aug 12, 2007 | 10:37 PM
speed_demon24's Avatar
I'm sure you can just get the oil level sensor tuned out when you get your car tuned.
Old Aug 12, 2007 | 10:44 PM
SS RRR's Avatar
Yeah I dunno... My tuner mentioned needing to do the same to his gf's car so who knows. The good news is it runs and the pan doesn't leak a drop.
Old Aug 12, 2007 | 10:51 PM
Gripenfelter's Avatar
Mine isn't plugged in.
Old Aug 12, 2007 | 11:00 PM
IrocSS85's Avatar
I did that setup for a guy too, and we ended up just leaving it unplugged, and making an adapter plug that would allow his oil temp sender to go in there. had to make that short as possible and it was still very close to touching.
Old Aug 13, 2007 | 05:15 AM
jasonisdn's Avatar
tie the 2 wires together to cancel the signal out and put a plug in it. thats the way i did it and i am not getting a code for it.
Old Aug 13, 2007 | 05:27 AM
cehan's Avatar
The oil level sensor is just a switch, not really a sensor. Oil level up - switch closed; oil level down - switch open and you get the light. When I put my 242T pan on with the Hookers, I started getting the light intermittently. I guess the sensor is not down far enough in the pan to close the switch consistently. But I don't need a light to tell me the oil level is low, so I snipped the wires and shorted them together...no more light
Old Aug 13, 2007 | 05:35 AM
cehan's Avatar
By the way, Canton sells a plug that fits in the sensor hole, but you can't get the sensor out with the headers installed. I bought the plug, but I'm sure not going to remove the headers just to do that. I'll just wait 'til the next time I have a reason to go into the engine again.
Old Aug 13, 2007 | 07:04 AM
jasonisdn's Avatar
they charge like 9 bucks for that plug. take the sensor to lowes and match it. i found one in my buddys shop , i got really lucky i guess.
Old Aug 13, 2007 | 08:23 AM
SS RRR's Avatar
Thumbs up
thanks for the info.
Old Aug 14, 2007 | 07:06 AM
cehan's Avatar
The thread is an M20 x 1.5 straight thread with a crush washer seal. Good luck on finding that in Lowe's
Old Aug 14, 2007 | 09:32 AM
jasonisdn's Avatar
i guess i did get lucky then. the shop is a heavy duty equipment rebuild shop , that also paints the equipment. oh well i'll take what i can get.
Old Aug 14, 2007 | 10:26 AM
bingo's Avatar
I use an oil drain plug I found on the shelf at O'Reilly's.
Old Aug 15, 2007 | 09:24 AM
2nd_chances's Avatar
I heat taped the wires and left it in. Took a little patience to get it in around the headers.
QuickSilver02
Apr 7, 2015 11:12 AM
jasonduaine
Apr 1, 2015 08:09 PM
thenewkid
Nov 29, 2014 04:54 PM
DarkHorse
Aug 27, 2002 06:20 PM
