Canton 242T owners
Old Feb 16, 2007 | 09:19 PM
Mr.Whitey's Avatar
Canton 242T owners
Are most of you using the Canton gasket (88-100T) w/ good results? Anybody know the plug size needed for the oil level sensor fitting? How does that gold finish hold up to the elements and/or time? Any rust?
TIA
Old Feb 17, 2007 | 09:28 AM
94/96ZsM6s's Avatar
i used the felpro SBC repalcement oil pan gasket, no problems so far. the oil level sensor plug shoudl hve come with the pan!! make sure you only put 5 quats in the pan +filer quantity. don't use the lines on the stock dip sitck!!
Old Feb 17, 2007 | 09:37 AM
irishz28's Avatar
what was that? only 5 quarts? what lines on the stock dip stick?
Old Feb 17, 2007 | 05:00 PM
94/96ZsM6s's Avatar
call canton and they will say the same. 5 in the pan+oil filer volume. i put 6 quarts in 5in pan+1qt for filter. it will read at the VERY end of the dipstick in the middle of the twist at the end of the dipstick. don't fill it up to to stock oil level
Old Feb 23, 2007 | 05:29 PM
Mr.Whitey's Avatar
How about rust?
Old Feb 23, 2007 | 06:10 PM
SS Joe's Avatar
TIA
I just installed mine (its painted to match the engine, pewter metallic, and I used the Fel Pro gasket), and needed the plug too. I believe its m18, which a larger parts store should have(but not the one here). I just cut the original sending unit down, removed the plastic guts, and welded up the hole in it and screwed it back in (needed clearance for the o2).
Old Feb 23, 2007 | 06:18 PM
FASTFATBOY's Avatar
Canton sells the plug to go with it.
David
Old Feb 23, 2007 | 06:35 PM
Mr.Whitey's Avatar
Anyone using the rails from the stock pan on the Canton pan?
Thanks for the replies.
Formula Steve
Sep 19, 2023 08:31 AM
frankrizz
Sep 23, 2015 04:33 PM
frankrizz
Sep 23, 2015 04:21 PM
cmsmith
Sep 14, 2015 09:09 PM
