cant wont start ASAP
Old Apr 25, 2004 | 03:46 PM
pyrojoex28's Avatar
i had to fix the turn signal switch, so i had to tear the steering wheel apart. got everything back together, but now the car wont start. when i turn the ignition to start, it makes a click and thats it. not the battery because i just bought a brand new one. im thinking something to do with a wire somewhere. need to get this fixed ASAP because I need the car running tomorrow.
Old Apr 25, 2004 | 06:28 PM
pyrojoex28's Avatar
need to fix this tonight, any insight at all?
Old Apr 25, 2004 | 06:36 PM
Bersaglieri's Avatar
Coil/Coil Wire off? I am not sure since my car is fugged up too and the dealership said it was the opti
-Dustin-
Old Apr 25, 2004 | 06:37 PM
Jasonz28camaro's Avatar
did you have to disconnect the battery? If so check to make sure they are really tight. Also try a jump even though your battery is new. If you had the domes on for hours it possibly could have wore it down
Old Apr 25, 2004 | 06:48 PM
pyrojoex28's Avatar
im positive its not the battery. i just checked the connections, and it had the charger on it before it was installed.
i unplugged the PCM fuses hoping a reset would fix it, but now its different. before there was a clicking sound under the dash, not the rod. it was in a different location. now theres only the rod sound under the dash, and some heater valve goin off under the hood.
the starter is not kicking in or anything. its almost like the battery is completely dead, but everything has plenty of power.
Old Apr 25, 2004 | 07:52 PM
pyrojoex28's Avatar
could this be a VATS issue? i measured the resistance on the key and it was around 2K ohm. i measured the resistance in the connector and got 3 different numbers. 6k, 9k, and less than 1K. could the dealership tell what number it should be from the VIN? also, if this is the problem how would i put in the resister, solder?
Old Apr 25, 2004 | 09:30 PM
Do you mean you measured back toward the key cylinder from the plug at the bottom of the steering column and got several different readings? That would indicate damaged wires or problem with the key cylinder or key.
Is the security light staying on?
Old Apr 25, 2004 | 09:32 PM
pyrojoex28's Avatar
yeah, i measured the other end of the plug, and got several dif readings. not sure where the key was. the security light flashes when the steering wheel is unlocked.
Old Apr 25, 2004 | 09:33 PM
This may not help at all but its all I can think of. Can you turn the key to the on position and manually start the car from jumping the starter? Perhaps if you can just get it started one time it a will start agian !
Old Apr 25, 2004 | 09:44 PM
turbo_Z's Avatar
maybe you messed up the ignition switch? how far did you work down the steering column?
Old Apr 25, 2004 | 10:06 PM
pyrojoex28's Avatar
i dropped the whole steering column for easier access. i dont think i can jump the car fromt he starter because the fuel pump is not kicking in either.
Old Apr 25, 2004 | 10:26 PM
If the security light is staying on or flashing, read your key again and compare it to this table. Get some resistors to match and plug them into the harness (toward the VATS module) you unplugged under the dash.
Old Apr 26, 2004 | 06:55 AM
pyrojoex28's Avatar
how do i plug the resister in? the connector you are talking about has prongs on the inside, i dont see any way the resister would stay in place.
Old Apr 26, 2004 | 08:08 AM
I guess your options are to cut and splice the resistor in or maybe use some wire taps. If you think you will replace the key cylinder in the future, I would cut or tap on that side of the connector, so when you replaced the cylinder there would be no hacked up wiring.
Old Apr 26, 2004 | 04:20 PM
pyrojoex28's Avatar
i connected the resistors and the car started right up. i cut the wire and soldered the resistors to it. i wanted to see if it would start without it being plugged in, and it fired right up. starts with or without the resistors. kinda weird, but oh well.
as long as its running its cool with me.
Alex Barnes
Jan 24, 2015 10:21 PM
Brake_L8
Jan 20, 2015 09:44 AM
Amshnock
14
Jan 18, 2015 11:47 AM
ro2207
Dec 4, 2014 06:18 PM
