cant wont shift into 4rth, is it PCM or trans problem.
it does it some times, not always, u hit the gas and it wont go into 4rth ,only goes into 4rth at like high RPMS 6000 .
i think is the PCM,might be goin bad.
transmision is good, it was tuned up not long ago.
Auto or Standard? I had the same problem with my six speed... it wouldn't shift into fourth except extremely high RPM's then eventually it wouldnt shift into 4ht at all... eventually i ended up losing 3rd too... but the problem was that the 3/4 gear synchros were cracked
jb4xx
Feb 2, 2015 10:00 PM
Brake_L8
Jan 20, 2015 09:44 AM
Jan 5, 2015 07:14 PM
Jul 4, 2005 05:00 PM
