cant use my MSD wires =(
Old May 27, 2006 | 12:15 PM
crAzy95z28's Avatar
well the boot that fits to the dynaspark i have wont fit. The metal connector inside wont reach the nipple from the dynaspark...
this sucks!!
Old May 27, 2006 | 12:24 PM
StephenDeli22's Avatar
Re: cant use my MSD wires =(
Couldnt you just get a different metal connector?
crAzy95z28's Avatar
the wires already come rpemade wih the opti boot on them.
Old May 27, 2006 | 12:28 PM
hey01's Avatar
ahG!!!!!!!! I've had some issues with my MSD wires too. when i got my set i had 10 wires.
the COIL wire had 2 opti ends on it.........how the FK is the little opti end supposed to fit on the coil post!
crAzy95z28's Avatar
i got my coil wire finished. I found an extra boot from my old set of tm wires..
lol stupid msd. what a waist of 80$
Old May 27, 2006 | 12:35 PM
crAzy95z28's Avatar
i think im going to cut the end of the boot to make it shorter so it will fit.
Im sure this will work!
Old May 27, 2006 | 12:36 PM
hey01's Avatar
^ yep
werid the dynaspark uses the same cap so no reason for the MSD's not to fit..........unlesss they are just messed up from msd
yep thats it......bad msd set :-P
Old May 27, 2006 | 12:59 PM
LJ93Z28GM's Avatar
MSD is typically very good.
When people pull on and off the boots they slids them back and fourth on the wire they are just on there by means of a tight/press fit.
Just adjust accordingly you might have moved them around.
crAzy95z28 you stated it came with 10 wire. That means 8 plug wires and two other wires. One wire is for later model LT1 that have a different coil which is the reason for it to be the same on each end. The other wire in the kit should be an opti end and the other a 90 typical end. Take a look you might have overlooked this.
Old May 27, 2006 | 01:08 PM
crAzy95z28's Avatar
on the 180* boot the metal connector in there is flush where the boot stops. So it doesnt even come out..
its dumb
Old May 27, 2006 | 01:10 PM
crAzy95z28's Avatar
tried cutting them, same thing. i need new boots
Old May 28, 2006 | 06:32 AM
hey01's Avatar
I didn't know.......i had to measure them out and mark them off the website, and when i was doing that i noticed that funny one was the LT1 coil wire.
Noenav
Mar 1, 2019 07:38 AM
thenewkid
Apr 12, 2015 07:42 PM
armedtrigger
Feb 24, 2015 08:30 PM
ModdedNerd
Feb 5, 2015 04:37 AM
thenewkid
Nov 27, 2014 09:41 AM
