cant use my MSD wires =(
Re: cant use my MSD wires =(
ahG!!!!!!!! I've had some issues with my MSD wires too. when i got my set i had 10 wires.
the COIL wire had 2 opti ends on it.........how the FK is the little opti end supposed to fit on the coil post!
MSD is typically very good.
When people pull on and off the boots they slids them back and fourth on the wire they are just on there by means of a tight/press fit.
Just adjust accordingly you might have moved them around.
crAzy95z28 you stated it came with 10 wire. That means 8 plug wires and two other wires. One wire is for later model LT1 that have a different coil which is the reason for it to be the same on each end. The other wire in the kit should be an opti end and the other a 90 typical end. Take a look you might have overlooked this.
I didn't know.......i had to measure them out and mark them off the website, and when i was doing that i noticed that funny one was the LT1 coil wire.
armedtrigger
Feb 24, 2015 08:30 PM
