Can't Understand the Code
Old Mar 24, 2008 | 06:37 PM
Counted Out's Avatar
So I was running the codes on my car for the first time, and after the DTC 12, the SES light did the following sequence:
Flash, Flash, Pause, Flash, Flash, Flash, Flash, Flash, Flash, Flash, Flash
It repeated this code 3 times, like it is supposed to. What code is that?
Old Mar 24, 2008 | 07:44 PM
Well, if 12 is flash, pause flash flash then your long sequence is code 28.
1993 only--
Quad-Driver Module (QDM) #3 circuit
applies to:
- fan control relays
- a/c relay
Old Mar 24, 2008 | 07:55 PM
1993 only--
applies to:
- a/c relay
Could that be showing up because I have a Fan Control Switch?
Old Mar 24, 2008 | 08:09 PM
It depends on what it is and how it is wired.
Old Mar 31, 2008 | 05:45 PM
How can I clear the code?
Old Mar 31, 2008 | 09:46 PM
You clear the code by fixing the problem. If you don't wire the fan switch correctly, you can get a code.
Old Apr 2, 2008 | 04:32 PM
I think after that you have to disconnect the computer from the battery for so long though. I could be wrong.
Old Apr 2, 2008 | 05:53 PM
Removing power from the PCM for 30-seconds will clear the code. However, if the problem is still there, the code and the SES light will come right back the first time the PCM runs the diagnostic.
CARiD
Jun 18, 2015 08:56 AM
DarkKnight
Buyer/Seller Feedback
May 11, 2015 10:03 PM
aj2494
Mar 12, 2015 10:17 PM
InfernalVortex
Jan 17, 2015 09:35 AM
91Bird305
Aug 5, 2002 01:39 PM
