Can't Thread in new oil sending unit
Old Mar 29, 2006 | 06:29 PM
splcamaro_z28's Avatar
Ok i got the old oil sending unit out but it was broken in half so it was easy ,but i cant thread in the new one . It is like because it points towards the firewall and cant get the right angle to get it started .
But why when i look at shoebox's pic it looks like it should point towards the brake booster ? mine points towards the firewall , and cant get it thread in i tried for 2 hours before we closed to just get it stared , What gives ?
Old Mar 29, 2006 | 06:31 PM
Re: Can't Thread in new oil sending unit
o ya its a late model 1994 camaro z28
Old Mar 29, 2006 | 06:39 PM
BlackDog's Avatar
The sending unit is 2 pieces. The big black sending unit its self and a 90 degree elbow that screws into the top of the block.
Take a wrench and turn the 90 degree piece so the threads points towards the booster.
Old Mar 29, 2006 | 07:06 PM
its like iam iam missing #1 angle fitting i can see it a little from underneth the car but cant tell if it has both angle fittings ?
Old Mar 29, 2006 | 07:35 PM
OBE1 95Z28's Avatar
It's actually 3 pieces, 2 90 degree fittings and the sending unit itself. Here's a photo from Shoebox's site.
http://shbox.com/1/op_sensor.jpg
You may need to rotate one of the fittings to get it to point more towards the brake booster.
Old Mar 29, 2006 | 09:03 PM
either i moved the ange fitting when i removed the old one maybe . i find out tommrow ill post what happen
Old Mar 30, 2006 | 03:22 PM
yep the angle fitting where moved took some time but i got it all fixed .
BADAZZ_Z
Parts Wanted
Mar 5, 2019 12:55 AM
transam_388
Mar 15, 2015 11:53 AM
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
slothgrant
Aug 22, 2002 03:01 PM
