cant spin the tires? 94 z
Old May 3, 2003 | 04:12 PM
  #31
colorchange96's Avatar
maybe your not hitting the gas all the way. my car gets squirrely anywhere over 3/4 throttle from a stop and wont stop spinning till i chirp 3rd. this is a m6, but thats not even dumping the clutch just punching it from like a 10-15 roll.
Old May 3, 2003 | 04:37 PM
  #32
StreetZ's Avatar
When my friend first got his old 95 Z A4 he wasn't aware he had to run premium gas, and his car wouldn't even spin the tires with a tank of 87. It could always be something as simple as that....
Old May 3, 2003 | 04:53 PM
  #33
9TransAM4's Avatar
am i supposed to be running premium gas?
Old May 3, 2003 | 05:10 PM
  #34
cals400ex's Avatar
well premium is recommended for our cars. if you just drive normal without burying the throttle all the time i am sure an 89 octane will be ok. our premium around here is not even 93 octane and the quality is junk. the local shops just tell me to get the cheapest stuff i can here and run a tank of amoco or mobil through it when i happen to go out of town and see one of those stations.
Old May 3, 2003 | 05:15 PM
  #35
9TransAM4's Avatar
interesting, i have been running 87 regular in my car most of the time. i think i will put in some mobil 93 premium next fill up and see if the car feels any different. do you think i will notice anything?
Old May 3, 2003 | 10:33 PM
  #36
TorchRedZ28's Avatar
Um, i have been running 87 octane and my car will spin the tires yet. Since i need gas anyways maybe i will try some 93 and see if the tires light up anymore Plus I didn't know our cars where suppose to run of 93, I mean I could see using it if you had more mods than stock.
Old May 3, 2003 | 11:07 PM
  #37
scoobysnax83's Avatar
it says it right in the manual. And I also believe that it says use premium fuel on the gas cap cover. Its because if the compression ratio of our engines. Its much higher than most vehicles.
Old May 3, 2003 | 11:26 PM
  #38
CamaroGuy22's Avatar
Originally posted by 9TransAM4
i guess it really depends on the specific car. i still have the 2.73's in and i have some decent tires, but i can get going sideways from a stop if i mash the pedal down. i am an A4.. maybe some peoples auto's just act a little differently than others. also, many people have mods. there are many factors. my advice would be drive somebodys auto z28 that is stock, and see how it feels to your stock car. and then go through and check plugs, wires......
good luck
When i mash it i go sideways too sometimes...go figure lol
Old May 3, 2003 | 11:52 PM
  #39
Hey CamaroGuy, where are you at in MD?
Old May 4, 2003 | 11:14 AM
  #40
About 10 mins from Annapolis
Old May 4, 2003 | 12:09 PM
  #41
snakeatinZ's Avatar
how many miles are on the car? Mabey you already said this, Iand I was not paying attention? Mabey you have clogged cats? My cats were getting clogged, they came out with an off road y-pipe and it was like a toooootaly different car??? just some thing to check?
Old May 4, 2003 | 05:58 PM
  #42
KeVMaN's Avatar
mine would chirp for a while, but after intake and exhaust i can leave 50 feet of tread no problem. it just winds up so much faster with a couple boltons. Make sure you're in drive too, not OD. BTW, i have an auto w/ 172K miles.
Old May 4, 2003 | 06:40 PM
  #43
Gibbs's Avatar
I don't know fellas. It sounds to me like something could be wrong with the car. That thing should get nuts from a stop. My friends 95 Z is an auto and it'll do burnouts that'll put my 6 speed to shame. His does have 323's in it though. If I were you I'd take her down to autozone and have them check out your codes for you. It could just need a tune up.
Old May 4, 2003 | 11:08 PM
  #44
Jake77444's Avatar
Will have autozone scan codes tomorrow, will that show bad plugs or bad opti?
Old May 4, 2003 | 11:31 PM
  #45
Z28Nut's Avatar
If your 95 is an obd1 pcm with obd2 connector, I don't think Auto Zone can scan it, they don't have the right hook-up available . The Opti might show up on a scan but I don't think bad plugs will.
I run 315/35-17s with A4 and 2.73 gears and can roast them off on newer asphalt below 70*F but above that it depends on surface of pavement.
Tonight I ran a crotch rocket at a 10mph roll and though I lost, my 1-2 shift was pretty impressive when the rear kicked out a couple of feet to the side less than 2 car lengths behind the bike. It was only 50*F out tonight, though.
