Can't seperate them, How many bolt for bellhousing
Old Apr 22, 2005 | 12:26 PM
Sergio's Avatar
At this very moment i'm doing my first work on my Lt1 engine package.
It's a complete LT1 with the T56 still attached.
Now, i wanted to seperate the tranny from the block and removed 6 bolts from the bellhousing.
I however do NOT know how many bolts are holding it as i can't lift the package and since it's sitting on a wooden pallet i cannot look underneath.
I assume there are just 6 bolts but i'm having a hard time pulling the tranny from the package (probably due to the foam underneath it for extra protection).
So the question is: Are there just 6 bolts holding the entire bellhousing to the engine block ???
Old Apr 22, 2005 | 12:44 PM
Aries's Avatar
Re: Can't seperate them, How many bolt for bellhousing
6 bolts.
If the trans hasn't been off in a good while, it may take some effort to separate it. Also, if the motor was making a lot of torque, the dowel pins may have shifted slightly and will require you using a pry bar to separate the trans from the motor.
Old Apr 22, 2005 | 12:49 PM
Sergio's Avatar
Thanks man !
There is a gap on the top side and it's clear that the bellhousing lost contact there, but the overal weight on that damn pallet with foam in between makes it kinda hard.
Going back to the shed and use some more elbow grease !
Old Apr 22, 2005 | 01:06 PM
Sergio's Avatar
Got them seperated (about 1.5 inches) but it looks like it is stuck around the starter gear ..
Probably have to pull it back in a straight line but it's hard with that thing so low to the ground .....
Oh well, i'll just keep on trying
Old Apr 22, 2005 | 01:36 PM
whontime's Avatar
Did you remember to pull the clutch fork?
Old Apr 22, 2005 | 02:35 PM
Sergio's Avatar
Cutch fork ?
Hm, i do have the actuator out (thing that presses on it).
But i assume that fork needs to be removed also ? I assume it's that housing on the driverside right ?
Old Apr 22, 2005 | 03:26 PM
Daryn95Z's Avatar
You have to remove the spacer for the "actuator" (Slides off of the two studs on driverside) than pull back on the clutch fork. The trans. should than come off.
Old Apr 22, 2005 | 03:29 PM
That has to be the most asked question when someone is pulling a manual transmission, lol.
Old Apr 22, 2005 | 05:13 PM
Sergio's Avatar
I'm sorry for beating a dead horse but i have ALL the manuals, a LT1/LT4 rebuild guide and pretty much have seen quite a view 'How to' pages but i wasn't able to find a walk through.
Especially the manuals go into such great detail that i couldn't find this 'easy' task.
Oh well, i guess i'll learn no matter what
Old Apr 23, 2005 | 11:33 AM
Sergio's Avatar
Ok, it's off !
Apart from the Fork a plate (hold by 4 small bolts) need to be removed also as it's held back by the Flywheel.
BigWil
Mar 29, 2015 12:24 PM
maybe2fast
Mar 16, 2015 09:45 AM
Duke
Jul 31, 2002 05:13 PM
