Can't retrieve fault codes.
Old Sep 14, 2005 | 12:12 PM
  #16
Re: Can't retrieve fault codes.
Shoebox has all the answers.......
http://shbox.com/1/dlc2.jpg
Old Sep 14, 2005 | 12:26 PM
  #17
Originally Posted by joed
What tool does it take to pull right side 02 sensor out ? The exhaust flange is to close to use either a sensor socket or a deep socket. Not enough room for open end wrench either.
An O2 socket and a ratchet is what I used. There was 'just enough' room.
Old Sep 14, 2005 | 04:39 PM
  #18
Originally Posted by calaban
Advance carries an Actron code scanner that will scan 94 models for around 30 bucks. I was looking for myself this weekend. But I have a 95 with the OBDII connector and OBDI computer. Had to let my father in laws mechanic scan it with his high dollar Snap-on deal.
That Actron scanner is no more than a plug with a switch in the box to short the two pins. If may say it works on 94's on the box, but it does not. Been more than a few people here who have bought one, and taken it back when it doesn't work.
Old Sep 14, 2005 | 04:43 PM
  #19
joed's Avatar
I ended up using crowfoot with universal and long extension. Engine now comes out of open loop but after 20minutes of running and under hard accelaration there is a knock and can see it retarding the timing.
Old Sep 29, 2005 | 03:21 PM
  #20
joed's Avatar
Talking Re: Can't retrieve fault codes.
Finally got the car running last night, ended up being the dist cap shorting out internaly once it got hot. The cap is only 1 year old and was bought from Jason ( ordered complete GM opticrap ), so much oem parts being better than aftermarket. Can't wait till MSD starts shipping their cap and rotor.
Nayr
Mar 3, 2023 08:34 PM
truecontr3
Oct 11, 2015 09:30 AM
drt
Sep 27, 2015 04:39 PM
greenzee28
Sep 25, 2015 04:29 PM
