can't remove passenger side head???
i'm in the process of removing my heads...after i got all the bolts off of the driver side head and tapping it with a hammer using a block of wood the thing just slipped right off...
getting the bolts on the passenger side was a little harder because i had to jack up the motor to get to the last bolt and get the header out...
right now i have all the bolts off and can't get the head off...i looked around it and can't find any other bolts...i tried to use the same block of wood and hammer method as recommend in the manual but still no luck
i'm using a hanye's manual and retraced all my steps...and got all the bolts off that it mentioned...
i tried searching and looked at a detailed diagram of the top of the engine but can't find any other bolts that i am missing....
any suggestions...am i missing any other bolts...not sure what to do....
thanks in advance for your help
Mine was a biotch to get off too. I just kept knocking the hell out of it with the hammer and wood and jerked on it with my fingers in the runners, eventually a corner broke loose and I wiggled it off.
There is only 17 bolts and in the same pattern on both heads, its prolly just being stubborn.
Count the bolt holes. Also make sure the accessory bracket is not attached to it.
Originally posted by shoebox
.........Also make sure the accessory bracket is not attached to it.
~John
do you have a diagram of the accesory bracket...besides the 17 headbolts i didn't remove anything else off the side...
how many bracket bolts are there, how many are attached to the passenger head?
btw...thanks for all the replies and the help
Originally posted by NXz28
.......how many bracket bolts are there, how many are attached to the passenger head?
~John
As long as your not using metal wood
I don't see how you'd be hurting anything by hitting. I think there was two bolt for the acc. bracket, one right behind the ps pump and another to the right of it, kinda hidden, its a stud but I don't think there was anything bolted to it.
theres 2 bolts that hold the accessory bracket. guaranteed thats your problem. i overlooked them as well. one is directly behind the ps pulley, the other is like 3 inches to the right of it (and a bit up), youll find em. ittl come off no prob after that.
Chris Anderson
Jan 27, 2015 08:30 AM
Jul 4, 2005 05:00 PM
Wilson
Jul 21, 2002 05:08 PM
