Can't get the tranny back in!
Old Oct 20, 2003 | 04:43 PM
1FastRedZ's Avatar
I just dropped the new motor in and bolted up the McLeod and the tranny will not go back in. I used the alignment tool through out the install checked all clearances, and torqued it to spec. It get about a 1/4" away from the belhousing and stops and will not go any further. The pilot bushing is installed correctly also. Does anyone else have this problem with the ST?
Old Oct 20, 2003 | 04:52 PM
Are you sure you have the alignment dowels, between the tranny and the bell housing in the proper position? Are you sure you have the tranny level with the engine? If it isn't exactly in a straight line, the front of the input shaft will not slip into the pilot bearing? You have the clutch fork off the ball?
Old Oct 20, 2003 | 05:47 PM
badassT/A's Avatar
I had the same problem and it turned out that my pilot bushing was out just a hair too much. Tapped it in a little with a socket and all was well.
Old Oct 20, 2003 | 06:30 PM
1FastRedZ's Avatar
The fork is loose. I'll try the to mess with the bushing tommrow. Thanks for the replies.
Old Oct 23, 2003 | 06:31 PM
1FastRedZ's Avatar
I tried and tried. I put a new pilot bushing in. It's in all the way. And it is still about an 1/8th of an inch off. The bolt holes don't quite match up. I just have the front of the car in the air. Would it make a difference if the car was level? I've had a few of my friends who are very familar with these trannys and we're at a loss.
Old Oct 23, 2003 | 06:40 PM
RCF925's Avatar
Hook up the slave and push the clutch pedal in, It should go after that
Old Oct 23, 2003 | 07:15 PM
gb95zconv's Avatar
I pulled mine up the last 1/4 inch with the bolts a little at a time, but my holes were lined up.
Old Oct 23, 2003 | 07:33 PM
drewstealth's Avatar
Yeah i had that same problem. Couldn't figure out what it was. But i also used to bolts to pull the tranny in. I don't know if that messed anything up. But i do know 5,000 miles later i'm putting in a new clutch. Also tranny made a lot of noises while driveing it. Hopefully when i do it this weekend i won't run into the same issue. And hopefully i didn't ruin my input shaft.
Old Oct 27, 2003 | 07:41 PM
1FastRedZ's Avatar
The d@mn still will not go in. Everything is installed correctly, disengaged the clutch. I can spin everything w/ the driveshaft I don't know what else to do.
Old Oct 27, 2003 | 07:55 PM
Well i just did another clutch install yesterday. I'm using the mcleod single disc. I ran into the exact same problem as you are. Nothing i did could get it go that last tiny bit. I took of the pp and disc 5 times to get make sure it was lined up and it still woudn't go. The 2 little tabs on the side of the tranny wouldn't go into the holes. Finally after trying for about 5 hr's. I finally got it close enough that i felt comfortable about pulling it together with the bolts again. But all my bolts were lined up. I'm gonna put the fluid in it tonight and see how it goes. I'll let you know. I hope to god that it is correct because if it isn't then i think that i'm gonna just sell the car and get a different car. I really don't feel like droping the tranny and messing with it for another 14hrs. Nor do i have the time. Good luck with yours though.
Old Oct 27, 2003 | 08:06 PM
Kyle@CSS's Avatar
hey. Did you get it togther yet? I hope you get it in by nov 8th. Get up with me at the shootout.
Old Oct 28, 2003 | 03:23 PM
1FastRedZ's Avatar
I'm tryin like he!! to get it finished by then. It's looking grim though with the tranny. If I can get it in I'll try to bring it down there. Everything else is pretty much done. I'd like to put the cryo'd rear end to the test.
Old Oct 28, 2003 | 03:47 PM
RCF925's Avatar
I had the same problem as you installing my S/T. It was a 1/4" from going in. I finally put in all the bolts and snugged them up but didn't pull up tranny with them, I then hooked up slave and pressed in clutch and it popped in another 1/8" and then pulled it up with bolts. I have about 2000 miles on it and it works perfect, I think because of the thickness of the twin disk it's more difficult to have everything lined up, Thats what depressing the clutch pedal helps with. Good Luck, I know how frustrating it is
Sergio
Jan 27, 2016 04:27 PM
importkiller94
Jan 17, 2015 09:03 PM
nballisru
Dec 14, 2014 05:01 PM
mattszm6
Dec 14, 2014 07:09 AM
Snoman73
Nov 17, 2014 07:22 PM
