can't get seals off! help
Old May 1, 2006 | 04:19 PM
nb 96 z's Avatar
How do you pop out the opti seal and cam seal in the timing cover?? I've been trying to pry/pound them out and they won't budge.
Old May 1, 2006 | 08:28 PM
Jeff95TA's Avatar
Re: can't get seals off! help
Tapping them out from the rear of the cover should work. Maybe a dumb question, but did you put a few pieces of wood under the front of the cover and then try tapping them out? A small punch should do the job. Just keep tapping at various points around the seal.
Old May 1, 2006 | 08:49 PM
Stoopalini's Avatar
I used a pipe and sockets that fit in the seals to pound them out.
Just flip the cover over and place it on 2 pieces of wood, as previously posted. Then find something that fits inside the seal (large socket/pipe) and hit it hard with a hammer.
They should come right out with no prying.
Thomas.
Old May 1, 2006 | 09:02 PM
lt11997's Avatar
I used a seal puller and then the right seal installer to put them in.
Old May 1, 2006 | 11:43 PM
nb 96 z's Avatar
I finally got them out. I did put wood behind it and tried to pound it out with a screw driver. I kept going around the seal tapping it. It was just stuck in there good. Thanks for the replies.
colts0455
Sep 27, 2015 01:07 PM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
95mysticta
Aug 20, 2015 07:43 PM
86z28original
3rd Gen / L98 Engine Tech
Aug 20, 2015 12:20 PM
Bails098
Aug 17, 2015 05:15 PM
