Can't get it running
Old Aug 14, 2018 | 06:41 PM
  #16
Chimera96's Avatar
Re: Can't get it running
Originally Posted by zootzee
Ok when I hooked up the fuel gauge that's what I was getting 32. I took the vacuum line of the fuel pressure regulator and it when to 39-41.And when I reconnected it stopped back down
When I turn the car on the fuel pressure gauge doesn't move I had seen it go up to 20psi once I think.
But the car will only run for 5 minutes or less then won't start again until it suits for over an hour
when you turn key on, engine off, the FP gauge should "snap" to 43psi....then drop about 5 psi when the pump stops priming..not slowly rise
If you do get the motor started again let it run for a few minutes then shut off. Pull the vacuum elbow off FPR...is there any sign of fuel in that rubber nipple?
If so FPR is bad
On the start, run 10 min, then stall and not re-start until motor is cool again...text book symptom for a failing ICM. They may test good when room temp. If you take it to get tested again use a heat gun or hair dryer to heat it up and test to see if it is good
Old Aug 14, 2018 | 07:00 PM
  #17
zootzee's Avatar
Thanks for the replies. I really appreciate the help
The gauge slowly went up to about 15 that's it and it only stayed and then died wouldn't start again
If so FPR is bad
No sign of fuel in this line looks dry and new
I bought a new ICM and have it installed
This car only had 60,000KMS and never winter or rain driven
Old Aug 14, 2018 | 07:23 PM
  #18
Chimera96's Avatar
when the car stalls, did you have a FP gauge on it monitoring pressure?
If you can rule FP out as a problem...than it is ignition or the needle in a haystack bad wire connection "somewhere". The later can be a real PIA to find.
Example: When my car was about 2 years old it had sudden shut off, no start. Dealership kept replacing Opti's. Problem persisted. So I just started tugging on wires while motor was running in a blind attempt to find something. I just "touched" the plug going into top of Opti and engine immediately shut off. I gave each of the 4 wires a gentle tug and the brown wire just came out. That wire never got crimped when the harness was made. My assumption was the dealership would "push" in the connector thus setting the wire in so car started and ran so I was set...until the problem kept returning. So yeah it was a random find of the needle in the haystack but example of how something that simple will just prevent the motor from starting at all
Old Aug 14, 2018 | 07:54 PM
  #19
zootzee's Avatar
Yes the pressure Seems to drop but the question is because it's not getting fuel or because something else.
I've owned this car since 97 never had any issues at all.
I've since replaced the fuel filter, ignition control module, crank position sensor, fuel relay trying to solve. I'd love to know if it's the fuel pump before I take that.
Someone mentioned the security system but that wouldn't let the car ruin for longer than a minute before the system shut down the engine.
The thing is after it stalls out and I'm turning it over it seems to be starving for gas and no pressure reading on the fuel rail. That's where I'm thinking fuel pump failing or can't keep up so on it's way out?
Old Aug 14, 2018 | 08:21 PM
  #20
Pullngz's Avatar
If your getting a slow climb to 15 PSI, You have a fuel issue, have you ruled out leaking injectors? With no gas in the vacuum line, I would assume the diaphragm is still good, and not ruptured.
If your injectors are not leaking, you have a failing pump. Or possibly a crack in the hose inside the tank, not allowing pressure to be built. either way you need to get into the tank.
Old Aug 14, 2018 | 08:58 PM
  #21
zootzee's Avatar
I thinking that I need to get into the tank too.
Now the question cut a hole in the trunk or try to drop the exhaust and tank. My car is a convertible. I'm really leaning towards cutting an access hole?
Old Aug 15, 2018 | 10:02 AM
  #22
DrewHMS97SS's Avatar
You'll get mixed feelings on this. Without question, the filler neck on these cars makes getting the tank out a pain in the ***. That said, the sheet metal over the tank is a part of the structure of the car. I would personally drop the tank as extra work is in my opinion, worth ensuring the car is not weakened.
Old Aug 15, 2018 | 03:57 PM
  #23
zootzee's Avatar
I'm going to cut the hole. Now I just have to find the proper location to cut. Because it's a convertible
The plan then is to weld a metal brace around the hole and to use and tapping screws for the cover with sealer. This should give strength back to it
Old Aug 15, 2018 | 09:35 PM
  #24
There's a “trapdoor” sticky thread in the “Fuel and Ignition” forum. Post #122 has a link to a photo of the convertible location. Not so much a location difference as it is a structural difference.
https://www.camaroz28.com/forums/fue...th-gen-619463/
Old Aug 16, 2018 | 06:08 AM
  #25
zootzee's Avatar
Thanks for the post!
Old Aug 30, 2018 | 05:13 AM
  #26
zootzee's Avatar
Well new fuel pump in and everything is back to normal, thanks to everyone that replied!!!!!!!!
Old Aug 30, 2018 | 09:22 AM
  #27
Glad it worked out for you.
Thank you for following up with info regarding your solution. Wish everyone would do that.
hektyk
Feb 20, 2007 04:47 PM
tyrsmkr
Aug 30, 2006 03:04 PM
jadams94ta
Mar 19, 2004 04:24 PM
RobK
Jun 1, 2003 09:48 PM
Robbie_97z28
Feb 13, 2003 05:31 PM
