cant get last header bolt in!!!!
Old Jun 15, 2003 | 07:28 AM
1995redZ28's Avatar
Angry cant get last header bolt in!!!!
i am soooo close to being doen with this header install. last night i finally got my bolts after waiting for 2 weeks!! well i got all bolts in except the #6 primary bolt!! how the heck did you guys get that in? the priamry comes off the head and bends like 90deg. towards the back of the engine, so its hard to even get the bolt started in there straight!! i can barely get it started with my fingers, but then it tightens up, and im affraid to cross thread the hole if i just tighten it down. it seems tight though only because the bolt is rubbing against the primary! anybody experience this? any ideas?! if i can get this last bolt in after work tonight then i can FINALLY start her up!!!
Old Jun 15, 2003 | 07:48 AM
funina91ss's Avatar
try taking a shovel handle and moving the tube over the direction you need this is a common thing when installing headers.It will move fairly easy one way or another a few MM.And dont tighten up all the bolts untill you get them all started.Plus Never Sease works great.
Old Jun 15, 2003 | 08:22 AM
revtime's Avatar
Mine went in tight too. I know it was not cross threaded so I just torqued it on in there.
Don,t have to worry about that one coming loose.
Old Jun 15, 2003 | 08:36 AM
FastZinTennessee's Avatar
Put all the bolts in there a few turns first, then start running them in. It's a tight squeeze.
Good luck.
Old Jun 15, 2003 | 08:42 AM
Loosen your other bolts, pull the header flange away from the head, pass the bolt through the header flange and then thread it into the head. If that does not work, try a slightly shorter bolt.
Old Jun 15, 2003 | 08:44 AM
NVMYZ28's Avatar
on my MAC headers, I had to slightly enlarge one of the holes a touch with my dremel. Nothing excessive - just a slight shave off of one side of the hole.
Only do this after loosening all the header bolts like described above. If that doesnt work, you should be able to get away with enlarging the hold just a touch.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
maybe2fast
Mar 16, 2015 09:45 AM
SavageZ28
17
Jul 14, 2002 11:04 PM
