cant get crank hub off!!!
Old Feb 29, 2004 | 09:39 PM
RedWS6TA's Avatar
how hard is it supposed to be to get the crank hup off. is there some secret that i dont know about? i have just been tring to use the traditional harmonic balance puller. please someone help me out!
Old Feb 29, 2004 | 09:42 PM
RicocheT's Avatar
Yea man, I had a hell of a time getting one off one time. I don't recommend this way but I ended up using a big hammer to get it off.. Was going to put a new one on anyway. For some reason the puller would never seem to get it to start.
Old Feb 29, 2004 | 09:45 PM
RedWS6TA's Avatar
i might just buy a new one if i cant get this one off. please give a little more info on how you used the hammer and i might just have to try it your way. by the way where did you get your new one and how much did it run you. thanks
Old Feb 29, 2004 | 10:00 PM
Brandon 95 Z28's Avatar
How are you using the puller? Do you have three bolts threaded into the hub, with something inserted into the hub to push off of? Some people thread the crank bolt back in and push off of that. I used a 1/4" drive 6 inch long extension to psuh off of and it worked perfect.
Brandon
Old Feb 29, 2004 | 10:04 PM
ledfootz28's Avatar
go buy a haynes it tells u exactly how to get it off.it even tells u what size bolts u need to get it off.u do need a puller,i dont suggest a big ****in hammer,lol.
Old Feb 29, 2004 | 10:06 PM
RedWS6TA's Avatar
i do have repair manuals and do know how to use a damn puller but this thing is just some damn tight i cant get it to start to back off.
Old Feb 29, 2004 | 10:29 PM
turbo_Z's Avatar
are you pushing against a bolt?
if you dont have a long bolt to the same spec as the old crank bolt then you are just pushing against the hub itself instead of off the end of the crank.
Old Feb 29, 2004 | 10:54 PM
Yes, this is the "secret". The hub is not open in the middle like the SBC balancer. Just be careful of the crank threads.
Old Feb 29, 2004 | 11:09 PM
Seal's Avatar
dont use the one that clamps on... the screw in the middle will constantly walk off...
get the puller that screws into the threads, makes pulling out like 55 times easier
Old Mar 2, 2004 | 10:46 PM
RicocheT's Avatar
Sorry its been a while since I've been on, I got mine from Jegs I believe, its the fluidamper (however you spell it), it seems like a good piece to me. I think it was like 170 though, can't member.. Make sure its for the Lt1 so it'll clear the distributor.
Not sure if the hammer will work for you since its in the car, I had the motor out and pan off (motor spun some bearings) so I wasn't really worried bout messing up the hub/crank. I believe I used a long punch and hit on one side and the other until it started to move after it starts its pretty easy. Believe it or not it wasn't messed up very much from banging on it. I know its prolly a bad way to do it, but hey I was mad at the puller for not pulling it off!!!!!!!!
By the way I was using the puller that has the screw in the middle that sort of pushes it off. Still didn't work.
Old Mar 2, 2004 | 10:49 PM
jbird's Avatar
listen to shoebox, he is the dad
AviatorDave
Dec 19, 2016 06:35 PM
95craz28
11
Sep 12, 2015 07:47 AM
Daluchman1974
Sep 11, 2015 06:12 AM
Boss002
Jul 24, 2015 10:47 AM
Catmaigne
Jul 14, 2015 05:17 PM
