Cant Find A 7/16 X Bolt So I Can Install My Crank Hub?
Old Jan 7, 2008 | 12:49 PM
  #16
oldyellow49's Avatar
Just curious - are the threads on an LT1 crank the same a GEN1 small block? Have a GEN1 small block harmonic balancer installation tool (threaded rod, nut, washer and bearing) and wondered if it could be used.
Old Jan 7, 2008 | 01:01 PM
  #17
ulakovic22's Avatar
I believe they are the same, but the problem with most balancer installers is that the bolt isn't long enough. You can lightly tap the hub on and then possibly use it.
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Jun 23, 2016 08:42 PM
Queens94z28
Dec 20, 2014 09:11 PM
1LEThumper
Jul 14, 2003 12:45 PM
