HELP! How to remove coil from ICM??
Old Nov 26, 2003 | 03:04 PM
Sanger's Avatar
I am in the middle of replacing the coil, and just to find out it looks like it's riveted to the ICM. How can I get the coil off?
Old Nov 26, 2003 | 03:16 PM
DR.ZED's Avatar
If you take a flat screwdriver rest it on the head of the rivit on the backside (the side that sits on the head of the motor), and wack the top of the screwdriver with a hammer.
The expanded head of the rivit will fall off and then you'll have a flush surface on the back. This will allow you to push the rivet out.
Old Nov 26, 2003 | 03:36 PM
RamAir95TA's Avatar
Just drill the rivets out. They are made of a real soft metal, so it should be a piece of cake.
Old Nov 26, 2003 | 03:37 PM
InjectedSS's Avatar
WHAT HE SAID
Old Nov 26, 2003 | 04:46 PM
Sanger's Avatar
ok, i used a chisel and hammer and knocked the head off. after i just pulled the coil off and tapped the rest of the rivet out from the ICM. Thanks guys! Coil is in the car and it runs good.
ad356
Apr 11, 2015 11:12 PM
maybe2fast
Mar 16, 2015 09:45 AM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
Alex Barnes
Jan 24, 2015 10:21 PM
