Can you test a Fuel Pressure Regulator?
Old Jul 12, 2003 | 03:57 PM
RRios8191's Avatar
Is there a way to test it or should I just replace it?
Car runs better after new MAP sensor, but not perfect.
Old Jul 12, 2003 | 05:40 PM
whitehooptie's Avatar
Put a fuel pressure gauge on it. Rev up the motor a little. If the gauge moves, then the regualtor works.
Old Jul 12, 2003 | 05:45 PM
norcalstreet's Avatar
Pull the vacuum line off. If fuel comes out it's broken and should be replaced. Bad fuel pressure could also be a condition of a clogged fuel filter (easy to replace) or a bad fuel pump (not so easy to replace).
What problem are you having exactly?
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Jul 4, 2005 05:00 PM
F(ast)-body
Feb 26, 2003 09:05 AM
