can you pass emmisions when...
Old Nov 18, 2004 | 06:17 PM
DiabloGT's Avatar
can you pass emmisions when you have no cats (straight pipes) but you get the o2 simulators?
Old Nov 18, 2004 | 06:30 PM
1 Nasty Bird's Avatar
Re: can you pass emmisions when...
if your talking about your 99 then yes
if your talking about your 95 in IL it doesnt matter if you have a O2 sim, we get put up on rollers if our cars are OBD1 or older. You can pass without cats, many people do actually. You just have to make sure all your motors emmisions systems are operating correctly (other then the missing cats of course) and the engine has a fresh tune-up.
Old Nov 18, 2004 | 06:31 PM
of course the more mods donethe harder it is to pass without them.
Also if you get a bored emissions inspectro and they look under your car and see no cat thats an automatic fail.
Old Nov 18, 2004 | 07:17 PM
SickWS6's Avatar
it wont pass the visual aprt of it and that means it will fail
Old Nov 18, 2004 | 08:16 PM
Dave89IROC's Avatar
depends if they do a visual, some states only plug a scanner into OBD2 cars
Old Nov 18, 2004 | 08:25 PM
DiabloGT's Avatar
what about in MA? on the visual dont straight pipes look close enough to cats? with pacesetter long tubes will cats fit?
Old Nov 18, 2004 | 08:29 PM
Koby's Avatar
Why not just get some cheap Cats and hollow them out and then stick pipes through them? That way you have no cats and you can pass the visual in case they do it??
Old Nov 18, 2004 | 08:32 PM
DiabloGT's Avatar
would that pass the smog test or is there none?
Old Nov 19, 2004 | 12:05 AM
mebanditws6's Avatar
Yes you can pass a sniffer without cats unless you live in California. As long as your ignition system is working as it should and your fuel filter and air filter aren't clogged, you can. Make sure the car isn't running lean either as the hotter the combustion chamber, the more hydrocarbons produced.
Jason
Old Nov 19, 2004 | 08:33 AM
kevm14's Avatar
I'd say hotter leads to lower HC emissions, not higher. Hotter will increase NOx, however.
David Dempsey
Mar 12, 2016 12:42 AM
4586
Sep 6, 2015 03:10 PM
Steve69SS396
Track Kill Stories
Aug 17, 2015 08:48 PM
karpetcm
Aug 14, 2015 03:02 PM
Cam's maro
Aug 11, 2015 07:45 AM
