Can you drain just the radiator to pull the waterpump?
Do you need to drain the coolant from the block in order to pull off the water pump without a mess, or is draining the radiator enough to get the level below the pump? (I'm changing the optipieceofcrapspark.)
Re: Can you drain just the radiator to pull the waterpump?
I believe you need to drain the block too. I did the opti not long ago and the waterpump is down enough on the block that you'll need to drain it a good bit down.
tilt the car up on jack stands in the front and u dont have to drain the block then take the waterpump off and ull be just fine
Use this for a guide: http://www.streetillusionsracing.com.../opti/opti.htm
You don't need to drain the block if you jack the front of the car higher than the rear.
Just drain the radiator, remove the hoses and your good to go.
Magenta_Hearts
Mar 29, 2017 08:54 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
