Can you cross two of the OBD-1 pins to clear a code?
As topic states. I have a code that keeps popping up and Im to lazy to take apart the dash to disable the SES. Is there a combination of pins I can cross to always be cleaing the code?
Originally posted by aklim
How about fixing it?
Originally posted by Shockwave
Are you also too lazy to post in the appropriate forum?
Moving to LT1 Tech...
Craig
Craig
And this isnt about my Z, its about my s10.Besides, I want you to feel needed by posting it in the wrong forum.
4ht Gen F-Bodys come in 3 flavors..
-OBD-I, codes flash by shorting pins (1993 only)
-OBD-I, requires scanner (1994/95)
-OBD-II (96/97)
If your S10 happens to be an OBD-I similar to the 1993, you might be able to "flash" the codes on the ALDL connector by shorting 2 pins, but that won't "clear" them. And "clearing" them won't keep them from coming back.
If you want to stay in the dark, remove the (SES) light bulb....
-OBD-II (96/97)
carguyshu
Jan 22, 2017 11:19 AM
