Can too much oil hurt an LT-1?
Old Feb 17, 2003 | 10:16 PM
  #16
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
15 responces and all that was needed was 3 words "use the dipstick"
Old Feb 17, 2003 | 10:21 PM
  #17
Smokn '94 Z's Avatar
Talking
I put 5 in mine too...
Make it 16 Trey...
Old Feb 17, 2003 | 10:23 PM
  #18
Javier97Z28's Avatar
Moderator
17
5 quarts in mine w/ a filter change
Old Feb 17, 2003 | 10:34 PM
  #19
Fear The Z's Avatar
what I do is, fill up the oil filter, then put 5 qts in the top....comes to the line everytime
Old Feb 17, 2003 | 10:46 PM
  #20
ibanez6rg's Avatar
Oil
You guys are crazy...it only takes 4.5 quarts if you use syrup
Old Feb 18, 2003 | 02:49 PM
  #21
6spdws6's Avatar
My book lists, "4.5 quarts with filter change". and 4.5 quarts puts it right at the fill line.
Old Feb 18, 2003 | 02:57 PM
  #22
TedH's Avatar
You say they changed the oil pan? I assume the pre-filled the pan to see how much oil they should put in it first, then test fit the pan to the motor, provided a dipstick and marked the dipstick to the proper length.
Different pans take different amounts of oil.
I have a six quart Canton pan, plus an oil filter. I still only run
4 1/2-5 quarts of oil and according to my engine builder and Canton, that is just fine for my motor.
Old Feb 18, 2003 | 03:28 PM
  #23
Patman's Avatar
Why would you go to the trouble of running a bigger pan and not taking advantage of using more oil? The more oil you run, the less stress you put on that oil. I'd much rather run 6 quarts of oil compared to 4.5! That is quite a huge difference in stress levels on the oil.
Old Feb 18, 2003 | 03:49 PM
  #24
Dr.Mudge's Avatar
Maybe its a "better" pan/filter setup you have? There is a big filter which allows some more oil (PF-30/5?), there is also a variance of .5qt I think depending on what year pan you have.
Too much oil, will end up foaming up when the crank whips it to death, this should show up as froth on your dipstick if you are at that point. 1qt or so over probably wont be a problem, but go by your dipstick...
Old Feb 18, 2003 | 11:15 PM
  #25
phoenix64's Avatar
haha you guys use 4.5qts? I use 5 with a longfilter in my 3.8. Just seems strange to me.
Old Feb 18, 2003 | 11:34 PM
  #26
97 RedSS's Avatar
over 5qrts in my 383 causes bad windage issues...
Less than 5qrts and the psi drops 10 psi when I get around 5k
If I run EXACTLY 5qrts everything is fine..wierd huh
Cody
Old Feb 19, 2003 | 09:48 AM
  #27
HungryT/A's Avatar
Don't fill in more than 5 quarts!!!
I had to drain it, because the PCV was sucking up oil through the TB and ruined my injectors (probably). You definiately don't want to have oil in your intake->on your injectors->on your valves->in your chambers. period.
Old Feb 19, 2003 | 10:07 AM
  #28
Patman's Avatar
I've been running 5.5 quarts in mine for almost a year now, and have no problems like that.
Old Feb 19, 2003 | 10:13 AM
  #29
treyZ28's Avatar
DIPSTICK
Old Feb 19, 2003 | 10:20 AM
  #30
GREGG 97Z's Avatar
With the stock filter it was 4.5. With the oversized PF 35 it's about 5 quarts.
