Can these stock valve springs handle a big solid roller?
I'm refering to the valve springs that come with the AFR 210 LT4 race heads in the NON competition package. They're race ready heads. I know that AFR has improved the LT line up a year or so ago, I purchased mine before that improvement was made; not sure if a valve spring change was made as a base upgrade.
I'm major valve train problems and thought this may be the cause. More specific information is in the "Advanced Tech" section, but I'm trying to eliminate this potential cause as a possibility.
Rich
I only know that they're the stock springs that come on AFR 210 race ready heads in the non-competition package. I'm not sure if the springs have been changed since AFR improved the head design about 1-2 years ago.
The stock AFR 210 "race ready" springs, 636-650 lift? 248-254 at .050 on a 110 LSA; my engine builder is contacting AFR today and should report his findings to me this afternoon.
I don't know if I would trust an engine builder who had to ask if they were able! He should have a press to see if the springs are adequate for your needs. Even if AFR says they can handle what you need, they could still be worn to bad to be used. JMO.
Hard to believe AFR would install a spring that is good for both a hydraulic valve train, and the typical higher spring pressures of a solid roller valve train. You mentioned lift and duration capabilities, but did not quote the sping pressures.
This is what AFR quotes in the specs for the 210 LT4 heads:
1.550" OD Roller dual valve spring w/ dampener, AFR #8000
225lbs on seat, .710" maximum lift (upgrades available)
very simple if the builder was worth a toot.
check installed height....check the spring, for all the problems this guy is having something is terribly wrong. Like someone has no idea what they are doing.......Is this guy an engine builder or just a mechanic?
I was not told the exact spring pressures of the springs that I have, but I'll call them tomorrow and ask.
He's an engine builder.
If I was building a high-zoot solid roller motor (And I have built a few) I'd install the entire matching valvetrain. Why risk dropping a valve into the motor with unknown springs?
He builds a lot of carbureted big blocks and Pro Street engines. His N/A race car runs 7.20's at just over 190 mph. I just don't want to mention his name and shop on a public forum out of respect for him and his business.
well if he has done top sportsman motors and that type stuff a little LT1 should have been a walk in the park,
