Can the springs and RR's from the hotcam kit be used with the CC306 cam?
Old May 12, 2004 | 06:31 AM
snake_skinner93's Avatar
I have the springs and 1.6RR's from a hotcam kit and was wanting to go with a CC306 cam... will i have to buy springs and RR's for the 306 or will the ones i have from the hotcam kit work fine?
Old May 12, 2004 | 06:54 AM
madwolf's Avatar
Not sure about the rockers, but the springs will definetely not work.
Old May 12, 2004 | 08:22 AM
kostya_f's Avatar
Don't see why the RRs wouldn't work, but the springs cannot support that much lift.
Old May 12, 2004 | 11:50 AM
RealQuick's Avatar
1.6RR's are 1.6 RR's. The springs wont work.
Old May 12, 2004 | 06:26 PM
96capricemgr's Avatar
The GMPP rockers are only good to .550, GM speced this in order to stiffen them up. The 306 with 1.6 will be .544 .576 so I say no they wont work either. Not a lot of heads are going to flow well enough to bother with that much lift anyway. The springs are far from usable the HOT cam is about their limit and really the lobes on that are mild compared to most aftermarket cams.
Old May 13, 2004 | 06:30 AM
RealQuick's Avatar
In the first sentence here, dont you mean the springs are only good till .550 lift? The only thing that would really affect the rocker is geometry, or interference from something like the top of the spring (O.D. wise).
CamaroHeed
Mar 18, 2020 09:50 PM
WildRidez
Jan 16, 2015 03:10 PM
T/A lt1
Aug 16, 2002 11:24 AM
T/A lt1
Aug 15, 2002 01:53 PM
MJ_Z28
Aug 7, 2002 07:15 PM
